SophroCoach wrote:Here is the file without noise
You have posted an Audacity project file. It's just a text file that controls the actual audio in the _data folder of an Audacity project.
Please post an audio file as already requested, preferably WAV, and no more than 1 MB if you attach it here. You can upload larger files to Dropbox or similar and give us the link to download the file. Use File > Export... in Audacity to export a WAV.
If you open Audacity > Preferences, then the Quality section, then set the last drop-down (the second "Dither" box) to "None", does the noise go away?
