Serperate track from long audio file
Help for Audacity on macOS.
ewinwee
Post by ewinwee » Tue Jun 03, 2014 4:24 pm
Hello all. Just downloaded Audacity to try to make separate tracks out of a long audio file. I added labels to the beginning of each track, as instructed on the FAQ. I'm ready to "Export Multiple" from the file menu, but everything in the file menu is grayed out except for "open recent" and "import".
Any ideas?
Re: Serperate track from long audio file
Post by steve » Tue Jun 03, 2014 5:36 pm
Most commands are disabled during Play, Record and Pause.
Ensure that playback is Stopped (not just paused).
