Resizing the Audacity window
Help for Audacity on macOS.
maryallwright
Post by maryallwright » Tue May 13, 2014 7:21 pm
The window that displays audacity has expanded to cover the entire computer screen. How do I reduce it back to the size it was; it took up half the screen and I could view my voice scripts on the other side of the computer screen.
Re: Resizing the Audacity window
Post by kozikowski » Tue May 13, 2014 7:30 pm
Can you reach the green ball in the upper left? That's a size toggle.
Post by Gale Andrews » Tue May 13, 2014 10:10 pm
If there is no green ball, use COMMAND + / to exit Audacity Full Screen.
maryallwright
Post by maryallwright » Wed May 14, 2014 3:49 pm
The green ball reduces it maybe 15%. I need it to go back to it's original size which is about 50% of where it is now. I tried command+, using four fingers, but nothing happened. Am I doing it right?
Post by Gale Andrews » Wed May 14, 2014 6:33 pm
maryallwright wrote:The green ball reduces it maybe 15%. I need it to go back to it's original size which is about 50% of where it is now. I tried command+, using four fingers, but nothing happened. Am I doing it right?
COMMAND and , (comma, what you wrote) opens Audacity Preferences.
I suggest not using trackpads. Use your real computer mouse to click the green button. When the green button has made the Audacity window smaller, use your real computer mouse to drag the window at the bottom right corner. Drag leftwards and upwards to make the window smaller.
