How to change MP3 Export Bit Rate [SOLVED]
Help for Audacity on macOS.
kevb8ll
Post by kevb8ll » Mon May 05, 2014 9:39 am
Hi guys
I have just switched to a MAC and I have installed 2.0.5. However all my exports are in 128K. I can't find where I can increase that in the preferences. Would someone kindly explain where I can change it please?
Thanks.
Re: Export Bitrate in MP3
Post by steve » Mon May 05, 2014 10:38 am
In the Export dialogue, click on the "Options" button.
See here for more details: http://manual.audacityteam.org/o/man/fi ... ialog.html
kevb8ll
Re: How to change MP3 Export Bit Rate [SOLVED]
Post by kevb8ll » Mon May 05, 2014 10:49 am
Brilliant thank you.
