Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
- Quality Assurance
Post
by Gale Andrews » Wed Mar 26, 2014 4:52 pm
turnonthejets wrote:I finally upgraded to Mavericks and still can't get Soundflower working. I ran through the tutorial again and nada. Must be something on my system no if under a different OS I see the same issue?
We can't help further with this. Unless you are telling us that you can record from Soundflower in GarageBand but not in Audacity then it isn't an Audacity issue.
Ask on the Apple support forums, use a loopback cable or download what you are trying to record if it is a web source (search Google for how to do that).
