Importing from YouTube
Help for Audacity on macOS.
chsm
Post by chsm » Sat Jan 04, 2014 1:43 am
Hello, and TIA for help! I've used Audacity successfully in the past to clip short excerpts from longer videos on YouTube. I'd like to do it again, but I'm stymied at the very first step: I can't remember how I got the file from YouTube to my computer... I'd even be happy with just the audio part. This has to be something easy, since I figured it out once before, but... Thanks for help!!
Moderator note: no need to shout fella - making your posting appear in bold doesn't make it get read any quicker or dealt with any sooner - it only annoys the forum elves. I removed the bolding for you.
waxcylinder
Re: Importing from YouTube
Post by waxcylinder » Sat Jan 04, 2014 11:33 am
This tutorial in the Manual should help you with the audio part: http://manual.audacityteam.org/o/man/tu ... puter.html
But Audacity is purely an audio editor so will not help you with the video clips ...
