No Playback on MacBook (loud click instead)
Help for Audacity on macOS.
Re: No Playback on MacBook (loud click instead)
Post by Gale Andrews » Fri May 23, 2014 5:33 pm
Krakatoa wrote:I have this same issue. It is solved bu uninstalling 2.0.4 or 2.0.5 and installing 2.0.3. This issue started since I upgraded the OSX last night. Even when I uninstall the app, I get the click. Something is incompatible with the latest Mac OSX and 2.0.5 (and 2.0.4) but is fine with 2.0.3.
Did you upgrade to 10.9.3?
It's possible that reinstalling 10.9.3 might have cured it. Installing Mavericks over previous OS X does cause audio issues for some people, not just in Audacity.
Thanks for the comments.
Krakatoa
Post by Krakatoa » Sun May 25, 2014 3:44 pm
Yes, I accepted the 10.9.3 upgrade that came it early this week from the app store and Audacity didn't work since that point until I downgraded it to 2.0.3.
Post by Gale Andrews » Sun May 25, 2014 6:59 pm
All I am saying is - if you had installed 10.9.3 over 10.8 or earlier and have audio issues in other applications than Audacity, installing 10.9.3 again may cure them.
Simply reboot then as soon as you see the grey screen, press COMMAND + R to enter the OS X Recovery Utility then follow the steps.
Doing that probably won't help the Audacity issue, though one person has said that it did.
