Can't make Audacity 2.0.5 work with Citronic AC-1 (SOLVED)
Help for Audacity on macOS.
DigitalDunce
Post by DigitalDunce » Tue Oct 22, 2013 1:22 pm
Hi
Please can someone tell me how to use the Audacity 2.0.5 with the Citronic AC-1 USB device. I have downloaded the latest version of Audacity from the site and can open it but I'm unable to set it up for a MacBook Pro (OX 10.8.3).
Also, when I plug the Citronic into the laptop, there is no indication of this. A few years ago I successfully used the device on an old Mac G4 after installing a now obsolete version of Audacity from the CD that came with the Citronic - to convert a vinyl source into digital (but can't remember what I did!).
But now I can't coordinate Audacity with Citronic. Please please help!
Thanks.
Re: Can't make Audacity 2.0.5 work with Citronic AC-1 device
Post by Gale Andrews » Tue Oct 22, 2013 4:41 pm
DigitalDunce wrote:when I plug the Citronic into the laptop, there is no indication of this.
That's what you need to fix, obviously.
Try the green box "Detecting USB and Firewire devices" here: http://manual.audacityteam.org/o/man/fa ... l#flatline .
DigitalDunce
Post by DigitalDunce » Wed Oct 23, 2013 11:46 am
Problem solved! Thank you. Much appreciated Gale.
