Deleting the preferences file for audacity on the mac
johnythehess
Re: Deleting the preferences file for audacity on the mac
The problem is solved. Following the instructions left by Koz and Gale I was able to delete the preferences file. The crackling is gone and playback is as clean as ever. Thanks guys for all the help and hanging with me on this one.
