Forum-related announcements, polls, et al.
- Quality Assurance
Post
by Gale Andrews » Wed Oct 16, 2013 6:17 am
Release Candidate 2 builds for the upcoming Audacity 2.0.5 release are now available for testing:
2.0.5 contains fixes for:
- Frequent crashes occurred on importing audio files on some machines
- Files did not open using Finder "Open with", double-clicking the file or dragging the file to the Audacity icon.
Please reply to this topic if you encounter any problems, especially with file open or import.
steve on Fri Oct 27, 2017 8:43 am, edited 4 times in total.
Reason: updated to rc2
Post
by kozikowski » Wed Oct 16, 2013 6:51 am
I can install two different Audacity versions by calling one of them a different name, right? That's not going to cause chaos? I rather like 2.0.3 for actual work. Koz
- Quality Assurance
Post
by Gale Andrews » Wed Oct 16, 2013 6:58 am
kozikowski wrote:I can install two different Audacity versions by calling one of them a different name, right? That's not going to cause chaos? I rather like 2.0.3 for actual work. Koz
Yes. You can have multiple Audacity versions and it should not create problems with existing file associations with 2.0.3 or with Finder "Open with" identifying which Audacity is which.
billw58
Post
by billw58 » Wed Oct 16, 2013 2:05 pm
The DMG does not have everything inside an "Audacity" folder, as we have done in the past. This conflicts with the installation instructions: "Then to install Audacity, copy the "Audacity" folder from the newly mounted .dmg to /Applications or any other location of your choosing."
It also is "from an unidentified developer", so you have to right-click then choose "Open" from the context menu to get it to launch the first time. I thought we had fixed that, but I see that Paul's nightlies also have that problem
-- Bill
billw58 on Fri Apr 24, 2015 4:23 pm, edited 2 times in total.
Reason: corrections
- Quality Assurance
Post
by Gale Andrews » Wed Oct 16, 2013 4:40 pm
Thanks, Bill. Also it doesn't have Install.txt which seems pretty important if the build really isn't signed. I'm not clear whether the signage is broken or Apple changed something again in OS X 10.8.5.
- Quality Assurance
Post
by Gale Andrews » Fri Oct 18, 2013 8:35 pm
The developer signage and DMG structure will be corrected in the next rc2 release candidate.
