Crash Issues
londonsoundlab
Re: Crash Issues
btw, the crash point for me is at 300 files - any more BOOM
Re: Crash Issues
20,000 files, 300 at a time is going to take a while.
Have you thought of scripting a batch file (along the lines of what was suggested in the topic that I linked to)?
I'm not sure what scripting support there is on Mac OS X, but being Unix based you may have access to Bash. Does this mean anything to you or is it like a foreign language?
londonsoundlab
Re: Crash Issues
terminal/unix stuff for em is a pretty foreign language.
im aware of bash - but i dont know my way around in there
i can follow instructions well, but its a little over my head
not so great at scripting with applescript either
that link was just for converting them - without the normalizng and compression
Re: Crash Issues
I was thinking about SoX http://sox.sourceforge.net/londonsoundlab wrote:that link was just for converting them - without the normalizng and compression
It can do normalizing, compression, trimming and encoding.
There are some example scripts in this topic: http://forum.audacityteam.org/viewtopic ... 28&t=53669
I may be able to help a bit if you want to give this a go, but I'm not an expert with Bash, and I'm on Linux so some things that work here may not work on your machine. If you can get this to work then you may be able (after giving it a good test) be able to process the whole lot.
Are the files all in the same folder, or different folders - how do you have the files organised?
londonsoundlab
Re: Crash Issues
unfortunately - everythign that page said was over my head...
londonsoundlab
Re: Crash Issues
strange my last post from earlier never posted.
But i answered your qeustion
the files are given to me in batches averaging 1500 files
one folder - 1500 mp3s
Re: Crash Issues
and all files to be processed in the same way I presume?londonsoundlab wrote:the files are given to me in batches averaging 1500 files
That makes writing a script for SoX considerably easier.
Do you think you could do the following
- install SoX,
- Open the Terminal, navigate to a folder and enter a command,
- create a plain text file, edit it, save it to a specified folde and make it executable
londonsoundlab
Re: Crash Issues
yes - im sure i could follow set instructions
im a little concerned about how will i set the proper compression level? how will i know what sounds best woth this program?
i will not be able to try until tomorrow - as ive been sat this all day and it is now 1 am
if you send me some hints - i can get on it as soon as i can tomorrow...
thank you for all of your help
Re: Crash Issues
For MP3, the main settings for sound quality and size are the bit rate (kbps) and whether it is CBR or VBR. What settings are you using with Audacity?londonsoundlab wrote:im a little concerned about how will i set the proper compression level? how will i know what sounds best woth this program?
Due to possible patent issues, it is uncertain whether SoX will support MP3 encoding or not. Some builds do and some builds don't.
The safest assumption is that SoX will not support MP3 encoding, in which case we should be able to do the compression and normalizing with SoX and then "pipe" the output to LAME for encoding the MP3.
If however SoX does support MP3, then that makes things a bit easier.
Let me just check - is MP3 format essential, or would Ogg format be acceptable? Ogg format has similar compression rates to MP3 and is open source so is not encumbered with patent restrictions. The downside of Ogg format is that less programs support it natively (Windows Media Player does not support it by default), though it is easy to add an additional codec to your computer to add support for Ogg if you don't already have it.
The initial experiments that we will need to do are to apply SoX and Lame to single files and get the command line parameters correct. When we've got that right we can write the script that applies those settings to all files in a folder.
Let me know when you have SoX installed.
When SoX is installed, please run this in a terminal window and post the output:
Code: Select all
sox -h9/10 questions are answered in the FREQUENTLY ASKED QUESTIONS (FAQ)
jaimejames
Re: Crash Issues
Was using Audacity 2.0.4 with no issues, then while normalizing an mp3, it suddenly quit and I received the Audacity quit unexpectedly message. Now, nothing I do seems to work, and I've tried repairing permissions, repairing disk, uninstalling and reinstalling 2.0.4 and 2.0.3, to no avail. Restarting does nothing, as well as trying various methods described in this forum.
I'm not to savvy in a Mac environment, so think of me as a total noob who needs a patient guide to resolve this.
Here's the report:
Here's the report:
Code: Select all
Process: Audacity [484]
Path: /Users/jaimelim/Desktop/Audacity/Audacity.app/Contents/MacOS/Audacity
Identifier: net.sourceforge.audacity
Version: 2.0.4.0 (2.0.4.0)
Code Type: X86 (Native)
Parent Process: launchd [120]
Date/Time: 2013-10-11 17:52:20.845 -0700
OS Version: Mac OS X 10.6.8 (10K549)
Report Version: 6
Interval Since Last Report: 7354 sec
Crashes Since Last Report: 31
Per-App Interval Since Last Report: 82 sec
Per-App Crashes Since Last Report: 17
Anonymous UUID: AAE34181-67C8-40A9-8040-5679275E1C21
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000008
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 Reaktor5.MusicDevice.component 0x1fc30197 NIAudioUnitMusicEffectEntry + 247
1 ...ple.CoreServices.CarbonCore 0x94ace51f CallComponentDispatch + 29
2 ...ple.CoreServices.CarbonCore 0x94ace500 CallComponentOpen + 43
3 ...ple.CoreServices.CarbonCore 0x94acc7d8 OpenAComponent + 433
4 net.sourceforge.audacity 0x000824b8 AudioUnitEffect::AudioUnitEffect(wxString, ComponentRecord*) + 104
5 net.sourceforge.audacity 0x00084cfc LoadAudioUnitsOfType(unsigned long) + 156
6 net.sourceforge.audacity 0x00084eae LoadAudioUnits() + 30
7 net.sourceforge.audacity 0x000c0165 LoadEffects() + 2293
8 net.sourceforge.audacity 0x0004485f AudacityApp::OnInit() + 2671
9 net.sourceforge.audacity 0x00046cc1 wxAppConsole::CallOnInit() + 17
10 net.sourceforge.audacity 0x0054a320 wxEntry(int&, wchar_t**) + 112
11 net.sourceforge.audacity 0x0003f24b main + 91
12 net.sourceforge.audacity 0x0003efae _start + 216
13 net.sourceforge.audacity 0x0003eed5 start + 41
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x999d0382 kevent + 10
1 libSystem.B.dylib 0x999d0a9c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x999cff59 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x999cfcfe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x999cf781 _pthread_wqthread + 390
5 libSystem.B.dylib 0x999cf5c6 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x999cf412 __workq_kernreturn + 10
1 libSystem.B.dylib 0x999cf9a8 _pthread_wqthread + 941
2 libSystem.B.dylib 0x999cf5c6 start_wqthread + 30
Thread 3:
0 libSystem.B.dylib 0x999a9afa mach_msg_trap + 10
1 libSystem.B.dylib 0x999aa267 mach_msg + 68
2 com.apple.CoreFoundation 0x93dce2df __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x93dcd3c4 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x93dcd1f1 CFRunLoopRunInMode + 97
5 com.apple.audio.CoreAudio 0x98fb496c HALRunLoop::OwnThread(void*) + 162
6 com.apple.audio.CoreAudio 0x98fa0488 CAPThread::Entry(CAPThread*) + 140
7 libSystem.B.dylib 0x999d7259 _pthread_start + 345
8 libSystem.B.dylib 0x999d70de thread_start + 34
Thread 4:
0 libSystem.B.dylib 0x999a9c0e mach_wait_until + 10
1 libSystem.B.dylib 0x99a31429 nanosleep + 345
2 net.sourceforge.audacity 0x00050234 AudioThread::Entry() + 100
3 libSystem.B.dylib 0x999d7259 _pthread_start + 345
4 libSystem.B.dylib 0x999d70de thread_start + 34
Thread 5:
0 libSystem.B.dylib 0x999a9b36 semaphore_wait_trap + 10
1 ...Rig 4.MusicDevice.component 0x17653560 NI::RIG::AUDIO::SuspendResumeThread::run() + 32
2 ...Rig 4.MusicDevice.component 0x17418316 NI::GP::Thread::execute(void*) + 54
Thread 6:
1 ...Rig 4.MusicDevice.component 0x1790d8cb NI::MEDIA::Asyncer<NI::PM::UndoBuffer>::run() + 395
Thread 7:
Thread 8:
4 com.apple.CoreFoundation 0x93dd3304 CFRunLoopRun + 84
5 ...Rig 4.MusicDevice.component 0x17418316 NI::GP::Thread::execute(void*) + 54
6 libSystem.B.dylib 0x999d7259 _pthread_start + 345
7 libSystem.B.dylib 0x999d70de thread_start + 34
Thread 9:
2 libSystem.B.dylib 0x99a312ca usleep + 61
3 ...Rig 4.MusicDevice.component 0x1779b489 NI::RIG::COMP::RigKontrol2Interface::onTimer() + 825
4 ...Rig 4.MusicDevice.component 0x1779b5ab NI::RIG::COMP::RigKontrolUpdateThread::run() + 27
Thread 10:
Thread 11:
3 ...Rig 4.MusicDevice.component 0x17677572 NI::RIG::COMP::RigKontrol3Interface::onTimer() + 610
4 ...Rig 4.MusicDevice.component 0x176775cb NI::RIG::COMP::RigKontrol3UpdateThread::run() + 27
Thread 12:
3 ...Rig 4.MusicDevice.component 0x17655dcb NI::RIG::COMP::RigKontrolManagerAudio::onTimer() + 1243
4 ...Rig 4.MusicDevice.component 0x17655ecb NI::RIG::COMP::RigKontrolManagerUpdateThread::run() + 27
Thread 13:
3 ...nth 5.MusicDevice.component 0x1a008920 ProgramChangeThread::run() + 32
4 ...nth 5.MusicDevice.component 0x1a2c6936 NI::GP::Thread::execute(void*) + 54
5 libSystem.B.dylib 0x999d7259 _pthread_start + 345
6 libSystem.B.dylib 0x999d70de thread_start + 34
Thread 14:
Thread 15:
Thread 16:
Thread 17:
Thread 18:
Thread 19:
Thread 20:
Thread 21:
5 Kore2.MusicDevice.component 0x1db96526 NI::GP::Thread::execute(void*) + 54
Thread 22:
Thread 0 crashed with X86 Thread State (32-bit):
eax: 0x1fa32630 ebx: 0x1fc300b7 ecx: 0x00000000 edx: 0x0001adb1
edi: 0x00810016 esi: 0xbffff724 ebp: 0xbffff6e8 esp: 0xbffff6b0
ss: 0x0000001f efl: 0x00010206 eip: 0x1fc30197 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x00000000 gs: 0x00000037
cr2: 0x00000008
Binary Images:
0x1000 - 0xab4ffb +net.sourceforge.audacity 2.0.4.0 (2.0.4.0) <FB28C2AD-97AB-6771-96F9-9216E4B3D108> /Users/jaimelim/Desktop/Audacity/Audacity.app/Contents/MacOS/Audacity
0x10a7000 - 0x10f3ffb com.apple.audio.midi.CoreMIDI 1.7.1 (42) <FB4D4B64-6ABB-679E-3AA8-21DE9062B4C1> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0x118c000 - 0x118dff7 com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x17f9000 - 0x17f9ff7 +hard_limiter_1413.so ??? (???) <DF93382E-6CFD-32EE-5FBA-1F428F821839> /Users/jaimelim/Desktop/Audacity/plug-ins/hard_limiter_1413.so
0x16ace000 - 0x16ad0ff7 +sc4_1882.so ??? (???) <8EA4B893-DD1B-CFAB-42B4-65C3695A7869> /Users/jaimelim/Desktop/Audacity/plug-ins/sc4_1882.so
0x16d6c000 - 0x16d70ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <E9CB576C-283B-1DB2-0C69-E7C914BD7922> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x16d75000 - 0x16d7bff7 com.apple.audio.AppleHDAHALPlugIn 2.0.5 (2.0.5f14) <38E3C1A4-84E4-C105-B55F-8FC4C154036D> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x16df9000 - 0x16e51fff +com.DivXInc.DivXDecoder 6.8.4.3 (6.8.4) <26A406B3-E4BC-C6FF-8F28-A99FFEB5CF2D> /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
0x16e75000 - 0x16e78ffb +com.divx.divxtoolkit 1.0 (1.0) /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
0x1709c000 - 0x17eceff7 +Guitar Rig 4.MusicDevice.component 4.0.7 (R960) (4.0.7 (R960), Copyright © 2009 Native Instruments) <F5562B2F-9BC2-A3B4-56CC-EE3B749B97CA> /Library/Audio/Plug-Ins/Components/Guitar Rig 4.component/Contents/MacOS/Guitar Rig 4
0x1a000000 - 0x1a881fe7 +Absynth 5.MusicDevice.component 5.0.0 (R829) (5.0.0 (R829), Copyright © 2009 Native Instruments) <8F29D37E-6D75-3087-72C4-3B721A0DD601> /Library/Audio/Plug-Ins/Components/Absynth 5.component/Contents/MacOS/Absynth 5
0x1d800000 - 0x1e61effb +Kore2.MusicDevice.component 2.1.0.009 (2.1.0, Copyright © 2009, Native Instruments) <D7EDB4A7-3F5A-0EAF-792D-47300E861045> /Library/Audio/Plug-Ins/Components/Kore2.component/Contents/MacOS/Kore2
0x1fc00000 - 0x209d4fcf +Reaktor5.MusicDevice.component 5.1.4.002 (5.1.4, Copyright © 2005 Native Instruments) /Library/Audio/Plug-Ins/Components/Reaktor5.component/Contents/MacOS/Reaktor5
0x70000000 - 0x700cbfff com.apple.audio.units.Components 1.6.5 (1.6.5) <412DBD1B-E9B5-E67C-99E4-820BF38239AC> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8fe00000 - 0x8fe4163b dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
0x90003000 - 0x900e3fe7 com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x90253000 - 0x90688ff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90689000 - 0x906a8ff7 com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x906b3000 - 0x906b3ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x906b4000 - 0x906d8ff7 libJPEG.dylib ??? (???) <50E17B4D-63D6-24D3-702F-6A6E912A55EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x906d9000 - 0x907dbfe7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <EB34F049-D9E1-BF19-CF03-B26A0352D40C> /usr/lib/libcrypto.0.9.8.dylib
0x907dc000 - 0x907dfff7 libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x907e0000 - 0x907e3fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x907e4000 - 0x907eeffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x907ef000 - 0x908a7feb libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x908b9000 - 0x908b9ff7 com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x90929000 - 0x90aecfeb com.apple.ImageIO.framework 3.0.6 (3.0.6) <AE641FAD-DF38-AE31-B45B-85AEE7AF3A45> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x90b0f000 - 0x90b40ff7 libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x90b44000 - 0x90b45ff7 com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x90b46000 - 0x91429ff7 com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x91460000 - 0x91464ff7 IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x91465000 - 0x91502fe3 com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x9150b000 - 0x91511fe7 com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x91534000 - 0x9153afff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x9153b000 - 0x9157dff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x915b7000 - 0x915c2ff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x915d9000 - 0x9161fff7 libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x91620000 - 0x91670ff7 com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x9170a000 - 0x91838fe7 com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x918a8000 - 0x919e5fe7 com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x91f01000 - 0x9200dfe7 libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x92117000 - 0x92125ff7 com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x92145000 - 0x92469fef com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9246a000 - 0x92473ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x924f9000 - 0x92556ff7 com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x925b0000 - 0x925f1ff7 libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x92e12000 - 0x92ebffe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x92ec0000 - 0x92edcfe3 com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x92edd000 - 0x92eddff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x92ee6000 - 0x92f96fe3 com.apple.QuickTimeImporters.component 7.6.6 (1800) <D7E3D86B-1DEA-FB86-E531-2ADD26077155> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x92f97000 - 0x93097fe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <BE7FCD73-03B5-25A4-FCA4-D4980F1488D6> /usr/lib/libxml2.2.dylib
0x930ac000 - 0x93165fe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x93166000 - 0x93460fef com.apple.QuickTime 7.6.6 (1800) <D3538A45-5F4B-262A-06AB-64C1EBAC4A33> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x938b3000 - 0x938f6ff7 libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x938fd000 - 0x93911fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x93953000 - 0x93953ff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x93954000 - 0x93a10fff com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x93a68000 - 0x93a6cff7 libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x93d91000 - 0x93f0cfe7 com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93f0d000 - 0x93f2cfe3 libexpat.1.dylib 7.2.0 (compatibility 7.0.0) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x93f2d000 - 0x93f80ff7 com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x93f88000 - 0x942f3ff7 com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x942f4000 - 0x9430cff7 com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x94316000 - 0x9440aff7 libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x9440b000 - 0x944b3ffb com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x944ff000 - 0x94501ff7 libRadiance.dylib ??? (???) <090420B3-CB65-9F7B-5349-D42F2F9693B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x947fc000 - 0x9481cfe7 libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
0x9481d000 - 0x9481dff7 com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9481e000 - 0x9483cfe7 libPng.dylib ??? (???) <6C0B95D7-9634-E044-0B79-F1DD56961C33> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x9483d000 - 0x94865ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <E761F29A-328B-29D9-3DF0-023F2C21E500> /usr/lib/libxslt.1.dylib
0x94a45000 - 0x94a66fe7 com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x94a67000 - 0x94d87ff3 com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94f14000 - 0x94f51ff7 com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x94f52000 - 0x94f5dff7 libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x95007000 - 0x9503aff7 com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x95047000 - 0x9504eff7 com.apple.agl 3.0.12 (AGL-3.0.12) <A5FF7623-9F55-0364-AD9B-42CF13C677C1> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x95052000 - 0x95085fff libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x95086000 - 0x95094fe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x950c1000 - 0x950e3fef com.apple.DirectoryService.Framework 3.6 (621.16) <5566E769-6459-78A7-DD2C-1D3068BD3932> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x953fc000 - 0x953ffffb com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x95400000 - 0x95582fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <60FF302E-5FAE-749B-BC70-0496DC2FBF2D> /usr/lib/libicucore.A.dylib
0x95583000 - 0x957f4fef com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x957f5000 - 0x958a1fe7 com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x959a9000 - 0x959e3ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <A6C207E3-7B42-926D-9C93-BE3F50B92496> /usr/lib/libcups.2.dylib
0x959e4000 - 0x95a0affb com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x95a8d000 - 0x95addfe7 libTIFF.dylib ??? (???) <AB182CEC-188A-F2BC-21E1-0059FD3B2598> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x95d0f000 - 0x95d79fe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x95d7a000 - 0x95d81ff3 com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x95dd1000 - 0x965c0557 com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x966c4000 - 0x97617ffb com.apple.QuickTimeComponents.component 7.6.6 (1800) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
0x97618000 - 0x976f2fff com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x976f3000 - 0x9781cfe7 com.apple.WebKit 6534.59 (6534.59.10) <73348DE8-9C7D-3BD9-8E9D-86E5BE67B1D1> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x979d1000 - 0x97de7ff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x97de9000 - 0x97eb4fef com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x97ee0000 - 0x97ee0ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x97ee1000 - 0x97f8fff3 com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x97f90000 - 0x97f9cff7 libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x981a1000 - 0x98f19fe7 com.apple.WebCore 6534.59 (6534.59.6) <5C71C61C-0657-1B0E-397F-4D0A81872C93> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x98f1a000 - 0x98f1aff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x98f1b000 - 0x98f2bff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x98f2c000 - 0x98f3eff7 com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x98f80000 - 0x98ffafff com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x9908c000 - 0x9911efe7 com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x9911f000 - 0x991b7fe7 edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x991b8000 - 0x991f3ffb libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x991f4000 - 0x991f7ff7 libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x991f8000 - 0x9923cff3 com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x9923d000 - 0x992bdfeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x992be000 - 0x992cbff7 com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x992cc000 - 0x992d0ff7 libGIF.dylib ??? (???) <2251F789-B187-0837-6E38-A0E5C7C4FA3C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x99454000 - 0x994b5fe7 com.apple.CoreText 151.13 (???) <23F359DA-D845-5C50-4DF3-19E858CF2B2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x99534000 - 0x99534ff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x99535000 - 0x995b7ffb SecurityFoundation ??? (???) <C4506287-1AE2-5380-675D-95B0291AA425> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x995b8000 - 0x995bdff7 com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x995f1000 - 0x9989efff com.apple.JavaScriptCore 6534.59 (6534.59.11) <7F623AA5-A11B-4C26-D2FD-EB5B9DE73F85> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x998e3000 - 0x9997efe7 com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x9997f000 - 0x99990ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x99992000 - 0x999a6ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x999a7000 - 0x999a8ff7 com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x999a9000 - 0x99b50ff7 libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x99bb0000 - 0x99bb2ff7 com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x99bb3000 - 0x99c00feb com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x99c01000 - 0x9a27cff7 com.apple.CoreAUC 6.11.03 (6.11.03) <42B31B0F-18F9-29D2-A67C-7B81A47F6D67> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x9a363000 - 0x9a3c7ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x9a3c8000 - 0x9a499fe3 ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <C618942F-BC01-0565-18CF-477B63C02181> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x9a696000 - 0x9a705ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x9a706000 - 0x9a71bfff com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x9a75a000 - 0x9a9c0ff7 com.apple.security 6.1.2 (55002) <E88E133F-5FB3-446F-B753-2B8AD577B46A> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x9aaa0000 - 0x9aae4fe7 com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x9ab61000 - 0x9aba4ff7 com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x9aba5000 - 0x9abaffe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Model: MacBookPro4,1, BootROM MBP41.00C1.B03, 2 processors, Intel Core 2 Duo, 2.6 GHz, 4 GB, SMC 1.27f3
Graphics: NVIDIA GeForce 8600M GT, GeForce 8600M GT, PCIe, 512 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8C), Broadcom BCM43xx 1.0 (5.10.131.42.4)
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: Hitachi HTS723225L9SA62, 232.89 GB
Parallel ATA Device: HL-DT-ST DVDRW GSA-S10N
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8502, 0xfd400000 / 2
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x1a100000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x820f, 0x1a110000 / 4
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0230, 0x5d200000 / 3
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8242, 0x5d100000 / 2
Reason: embedded the report in code tags to aid readability
