I have two mono tracks that I want to merge in one stereo track.
* Change track A from mono to "Right channel"
* Change track B from mono to "Left channel"
* Select "Make stereo track" in track A
Then I have an stereo track. The issue is that track A is in the left channel and track B is in the right one.
I know how to get the track in the channels I want but I wander if this the expected behavior. Shall I report it as a bug?
Misleading behavior of Make Stereo Track
Re: Misleading behavior of Make Stereo Track
Probably not. You have two mono tracks you want to mix down to two-track mono. That's different.I have two mono tracks that I want to merge in one stereo track.
Select the whole thing by double clicking anywhere in the blue waves and...
Tracks > Stereo Track to Mono.
That will mix the left and right together and produce a "real" mono track. If you did nothing else right there but File > Export, you would have a single track that will play to both stereo speakers.
If that bothers you, Select the whole thing and Edit > Duplicate. Using the drop-down to the left of the top track > Make Stereo Track.
That will give you two-track mono.
It's not a bug and yes, it's a little out of the way, but then what you did isn't particularly normal. You can also get that by duplicating each of the mono tracks at the beginning and make each one into a "stereo" show. When Audacity exports the work, it will mix the two stereo tracks to one stereo track. That's dangerous because you could get overload if both tracks got loud at the same time.
You could also have left your two original mono tracks alone and File Export. Audacity will mix down to one mono track. Both shows will appear on left and right in stereo systems.
No, it's not a bug. It is behaving as designed and as described in the manual: http://manual.audacityteam.org/o/man/tr ... html#splitsolkar wrote:I have two mono tracks that I want to merge in one stereo track.
Note that there is no need for your first two steps.
If you want Track B to be the left channel, simply drag the tracks into the correct order by clicking on the track control panel (left end of the track - taking care not to click on the sliders or buttons) and drag up or down.
There is also an overview of splitting and joining stereo tracks in the manual: http://manual.audacityteam.org/o/man/sp ... racks.html
Topic split to: http://forum.audacityteam.org/viewtopic ... 80#p224780
