Just used an Olympus Digital Voice Recorder to record a conversation.
One voice is very clear - other voices are very quiet.
Is there any way of increasing the volume of the track section that is too quiet?
Cheers,
Mike
Increase volume of a quiet recording
Re: Increase volume of a quiet recording
The best way is to painstakingly go through using the Envelope Tool to adjust the volume up and down. http://manual.audacityteam.org/o/man/envelope_tool.html
If you want a quicker way, you could try this "Automatic Gain Control" plug-in effect: http://forum.audacityteam.org/viewtopic ... 79#p194179
