"Studio" fade in for music?
Help for Audacity on macOS.
PRD
Post by PRD » Sun Sep 29, 2013 6:51 pm
Hi I'm using Audacity 2.0.3 on a mac OSX 10.8.4
I want to do a fade in to an MP3 song & to be able to determine the fade in period until its up to full (normal) amplitude. Is there a way to limit of dictate the time period (a few seconds) of the fade in? Like wise with a fade out effect with the fade occurring within a specified time.
I've done a search of the forum & read the manual but don't seem to see anything other than the fade in effect that fades the entire song.
Thanks. P
waxcylinder
Re: "Studio" fade in for music?
Post by waxcylinder » Sun Sep 29, 2013 8:48 pm
PRD wrote:I've done a search of the forum & read the manual but don't seem to see anything other than the fade in effect that fades the entire song.
The fade commands work on the portion of audio that is currently selected - so select just a short bit at the beginning for a fade in and ashort bit at the end for the fade out.
The Studio Fade Out will almost certainly give you a better (more musical) fade that the straight linear Fade Out.
There is no equivalent "Studio Fade In" effect but if you select the audio for a a fade-in and apply the fade three times that will give you a shaped fade, rather than a simple linear fade, which is usually much better.
Typically fade-outs are applied over a longer time than fade-ins, say 5-15 seconds for a fade-out and a fraction of second for a fade in.
