I can't seem to have the toolbar that edits the pitch
berrybunbun
Help I just downloaded this so I'm still a noob =_=
- Attachments
- Screen Shot 2013-09-26 at 10.54.47 PM.png (134.05 KiB) Viewed 1030 times
berrybunbun
I can't find my File menu
Can someone help me with this? I need to edit the pitch of a song for our program and unfortunately the whole file menu is gone. HELP
Re: I can't find my File menu
Is Audacity "In Front and Stopped?"
Click anywhere on the Audacity Top Bar and then File and see if the menus come back. If they don't, do you have any of the other menus like Edit, View and Transport?
- Quality Assurance
Merged the two topics.
Audacity > Quit Audacity.
Open Finder.
Go > Go to Folder and type:
Delete audacity.cfg.
Restart Audacity.
This will reset your settings as long as you never used Audacity 1.2 before.
Open Finder.
Code: Select all
~/Library/Application Support/audacity/
Restart Audacity.
