USB Codec Problem
USB Codec Problem
Audacity 2.0.4 (.dmg installer)
Mac OS 10.8.5
Opening Audacity I get an error: "Registry Error, Please insure this product has been installed properly" which hasn't been a problem until now. I think I read it was probably a plug-in compatibility issue. Now when using the USB Audio Codec there's an error on playback, " ERROR, Error while opening sound device, Please check output device settings and project sample rate." I double checked the settings. There's not a problem with recording. Playback works if output is switched to a different device.
I've repaired permissions and changed the config file so as not to load the plug-ins but there was no difference. I installed the zip but there was no change.
I also use Reaper and Twisted Wave & they both work fine.
Any suggestions are appreciated. Thanks.
Kirk
Mac OS 10.8.5
Kirk
- Quality Assurance
Re: USB Codec Problem
The "Registry Error" is not coming from Audacity so it is almost certainly coming from a plug-in.
Make sure Audacity is quit (Audacity > Quit Audacity) then replace the entire contents of audacity.cfg with this:
There is more help with editing audacity.cfg here: http://wiki.audacityteam.org/wiki/User: ... n_Mac_OS_X .
What device is the USB Audio CODEC? If it is a USB turntable or USB cassette deck, you cannot use it as a playback device for the computer.
Code: Select all
NewPrefsInitialized=1
[AudioUnits]
Enable=0
GUI=0
[VST]
Enable=0
GUI=0
Rescan=0
I'll get to work on this.
Thanks Gale,
Kirk
Thanks Gale,
Kirk
Thanks for the Info, should be able to fix it now.
The device is an Allen & Health ZED10FX mixing board. It's been working well until yesterday when the problem started.
Kirk
Kirk
I added the audacity.cfg file and audacity folder to /Library/Applications Support. It didn't change a thing so I unchecked all of the plug-ins in preferences and re-started Audacity. Didn't get the Error message as it was starting but that was the only thing that changed. I tried to open a file and it crashed. If I'm reading it correctly it looks like its com.apple.HIToolbox.plist which is in /Library/Preferences and not a plug-in so I was afraid to delete it & I couldn't upload it as the plist extension isn't allowed. Tried to change/add to the extension but the file changed too.
Here's a part of the report:
Code: Select all
Process: Audacity [44793]
Path: /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
Identifier: net.sourceforge.audacity
Version: 2.0.4.0 (2.0.4.0)
Code Type: X86 (Native)
Parent Process: launchd [533]
User ID: 501
Date/Time: 2013-09-22 20:55:42.821 -0600
OS Version: Mac OS X 10.8.5 (12F37)
Report Version: 10
Interval Since Last Report: 217307 sec
Crashes Since Last Report: 203
Per-App Interval Since Last Report: 34614 sec
Per-App Crashes Since Last Report: 9
Anonymous UUID: 6025215A-760B-0F5A-4124-13DA3E224F38
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000000b7ffffa
VM Regions Near 0xb7ffffa:
__LINKEDIT 000000000b771000-000000000b784000 [ 76K] r--/rwx SM=COW /usr/local/lib/audacity/libavformat.52.dylib
MALLOC_TINY 000000000b800000-000000000b900000 [ 1024K] rw-/rwx SM=PRV
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_c.dylib 0x958c19db memmove$VARIANT$sse3x + 1917
1 com.apple.HIToolbox 0x97e4720b CArray::ReplaceElements(long, long, long, void const*) + 125
2 com.apple.HIToolbox 0x97e6afad CUnicodeTextension::UnicodeReplaceRange(long, long, TReplaceParams const&, unsigned char, unsigned char) + 1873
3 com.apple.HIToolbox 0x97e6b591 CUnicodeTextension::ReplaceRange(long, long, TReplaceParams const&, unsigned char, unsigned char) + 97
4 com.apple.HIToolbox 0x97e5d17e CReplaceTextCommand::DoMainAction() + 74
5 com.apple.HIToolbox 0x97e5c799 CTextensionEditCommand::DoIt(short*) + 25
6 com.apple.HIToolbox 0x97e5c09e CTextensionCommand::Execute(short*) + 54
7 com.apple.HIToolbox 0x97e64387 OpaqueTXNObject::ExecuteCurrCommand() + 121
8 com.apple.HIToolbox 0x97e5f8a5 OpaqueTXNObject::NewCommand(short, AttrObjModifier const*, TKeyDownParams*, TReplaceParams*) + 1065
9 com.apple.HIToolbox 0x97e55502 DoSetDataCommand(OpaqueTXNObject*, unsigned long, unsigned long, TReplaceParams*) + 314
10 com.apple.HIToolbox 0x97e54ecd TXNSetData + 1037
11 net.sourceforge.audacity 0x0043cdc5 wxMacMLTEControl::SetTXNData(wxString const&, unsigned long, unsigned long) + 165
12 net.sourceforge.audacity 0x0043ced3 wxMacMLTEControl::WriteText(wxString const&) + 195
13 net.sourceforge.audacity 0x0043cab8 wxTextCtrl::WriteText(wxString const&) + 168
14 net.sourceforge.audacity 0x004ea4b9 wxLogWindow::DoLogString(wchar_t const*, long) + 137
15 net.sourceforge.audacity 0x005567e6 wxLog::DoLog(unsigned long, wchar_t const*, long) + 342
16 net.sourceforge.audacity 0x004ecaa3 wxLogWindow::DoLog(unsigned long, wchar_t const*, long) + 99
17 net.sourceforge.audacity 0x00037a7b wxLog::OnLog(unsigned long, wchar_t const*, long) + 235
18 net.sourceforge.audacity 0x00555fe1 wxVLogMessage(wchar_t const*, char*) + 113
19 net.sourceforge.audacity 0x0055605b wxLogMessage(wchar_t const*, ...) + 27
20 net.sourceforge.audacity 0x00125f02 Importer::Import(wxString, TrackFactory*, Track***, Tags*, wxString&) + 1794
21 net.sourceforge.audacity 0x00199aa5 AudacityProject::Import(wxString, WaveTrackArray*) + 149
22 net.sourceforge.audacity 0x0019da64 AudacityProject::OpenFile(wxString, bool) + 2196
23 net.sourceforge.audacity 0x000417aa AudacityApp::MRUOpen(wxString) + 410
24 net.sourceforge.audacity 0x00041ab5 AudacityApp::OnMRUFile(wxCommandEvent&) + 149
25 net.sourceforge.audacity 0x0059b0e3 wxEvtHandler::ProcessEventIfMatches(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) + 115
26 net.sourceforge.audacity 0x0059b25f wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 111
27 net.sourceforge.audacity 0x0059b62f wxEvtHandler::ProcessEvent(wxEvent&) + 207
28 net.sourceforge.audacity 0x0059b048 wxEvtHandler::TryParent(wxEvent&) + 56
29 net.sourceforge.audacity 0x0059b5dc wxEvtHandler::ProcessEvent(wxEvent&) + 124
30 net.sourceforge.audacity 0x004bba06 wxMenuBase::SendEvent(int, int) + 86
31 net.sourceforge.audacity 0x004201a8 wxMenu::MacHandleCommandProcess(wxMenuItem*, int, wxWindow*) + 72
32 net.sourceforge.audacity 0x003e647a wxMacAppEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1050
33 com.apple.HIToolbox 0x97dad9bb _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
34 com.apple.HIToolbox 0x97c35394 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
35 com.apple.HIToolbox 0x97c34780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
36 com.apple.HIToolbox 0x97c48655 SendEventToEventTarget + 88
37 com.apple.HIToolbox 0x97dad86a SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 498
38 com.apple.HIToolbox 0x97c24984 SendMenuCommandWithContextAndModifiers + 70
39 com.apple.HIToolbox 0x97c24931 SendMenuItemSelectedEvent + 268
40 com.apple.HIToolbox 0x97c247b6 FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 134
41 com.apple.HIToolbox 0x97df9e7e MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 623
42 com.apple.HIToolbox 0x97dfadc6 MenuSelect + 171
43 net.sourceforge.audacity 0x004481d0 wxMacTopLevelMouseEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1008
44 net.sourceforge.audacity 0x003e64ba wxMacAppEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1114
45 com.apple.HIToolbox 0x97dad9bb _InvokeEventHandlerUPP(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*, long (*)(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*)) + 36
46 com.apple.HIToolbox 0x97c35394 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1343
47 com.apple.HIToolbox 0x97c34780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
48 com.apple.HIToolbox 0x97c48655 SendEventToEventTarget + 88
49 com.apple.HIToolbox 0x97c685f6 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 2188
50 com.apple.HIToolbox 0x97c3583f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2538
51 com.apple.HIToolbox 0x97c34780 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 430
52 com.apple.HIToolbox 0x97c48655 SendEventToEventTarget + 88
53 net.sourceforge.audacity 0x003e4056 wxApp::MacHandleOneEvent(void*) + 38
54 net.sourceforge.audacity 0x003e412f wxApp::MacDoOneEvent() + 127
55 net.sourceforge.audacity 0x003fca53 wxEventLoop::Dispatch() + 35
56 net.sourceforge.audacity 0x0048f68f wxEventLoopManual::Run() + 111
57 net.sourceforge.audacity 0x004698d3 wxAppBase::MainLoop() + 83
58 net.sourceforge.audacity 0x0054a34a wxEntry(int&, wchar_t**) + 154
59 net.sourceforge.audacity 0x0003f24b main + 91
60 net.sourceforge.audacity 0x0003efae _start + 216
61 net.sourceforge.audacity 0x0003eed5 start + 41- Attachments
- CrashReport.txt
- added code tags for readability
- (45.5 KiB) Downloaded 63 times
- Quality Assurance
It wouldn't do - audacity.cfg goes in your home Library, that is ~/Library/Application Support/audacity.kirk202 wrote:I added the audacity.cfg file and audacity folder to /Library/Applications Support. It didn't change a thing
OK so you established the Registry Error was coming from am Audio Unit or VST plug-in. You could experiment with the VST plug-ins if you wanted to. Choose Audacity > Preferences, choose "Effects" on the left again, enable all the VST options (including the option to Rescan for VST plug-ins), then restart Audacity. In the "Install VST Effects" dialogue that appears, you can uncheck all the plug-ins except one, then click OK. If there is no error, repeat the steps, enabling an extra plug-in each time until you find the culprit.kirk202 wrote:I unchecked all of the plug-ins in preferences and re-started Audacity. Didn't get the Error message as it was starting
Of course it might be an Audio Unit plug-in. If it is, you can try this 2.0.5-alpha test build http://gaclrecords.org.uk/test-builds/a ... -2.0.5.zip that should put all the Audio Units in Audacity's Effect menu, but not load them until you choose them from the menu. So if it worked, you would not get the Registry Error until you chose the errant plug-in from the menu.
However that r12571 build has a bug that affects sound quality of exports, so only use it if needed to debug the Audio Unit that has the Registry Error.
If you find which plug-in caused this Registry Error, please tell us.
Are you saying you still get error opening when setting the Audacity playback device to the mixer? If so, you will probably need to set up the USB codec for the mixer. In Finder, choose Go > Utilities then open "Audio MIDI Setup". See here http://wiki.audacityteam.org/w/index.ph ... ices#setup .kirk202 wrote: but that was the only thing that changed.
2.0.4 has an import crashing problem so I suggest you use 2.0.3 or 2.0.5-alpha. You can find links to 2.0.3 or 2.0.5 alpha here: http://forum.audacityteam.org/viewtopic ... 47&t=74692 . The 2.0.5-alpha in that topic is later than the test build for Audio Unit loading, so it won't have the export quality issue.kirk202 wrote: I tried to open a file and it crashed.
Code: Select all
Process: Audacity [44793] Path: /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity Identifier: net.sourceforge.audacity Version: 2.0.4.0 (2.0.4.0) Code Type: X86 (Native) Parent Process: launchd [533] User ID: 501 Date/Time: 2013-09-22 20:55:42.821 -0600 OS Version: Mac OS X 10.8.5 (12F37) Report Version: 10 Thread 0 Crashed:: Dispatch queue: com.apple.main-thread 0 libsystem_c.dylib 0x958c19db memmove$VARIANT$sse3x + 1917 1 com.apple.HIToolbox 0x97e4720b CArray::ReplaceElements(long, long, long, void const*) + 125 2 com.apple.HIToolbox 0x97e6afad CUnicodeTextension::UnicodeReplaceRange(long, long, TReplaceParams const&, unsigned char, unsigned char) + 1873
Gale,
I think it may be Audio Unit AUMatrixReverb. I noticed that it didn't work in r1257, no error message, looked like it worked but nothing changed. Never got the Registry Error in r1257 either. But in 2.0.4 unchecking Audio Units got rid of the Registry Error.
Only the VST plugins show up in the menu when Audacity scans for them.
My system configuration was slightly off so fixing that fixed the codec problem.
Your help is much appreciated, thanks.
Kirk
Kirk
- Quality Assurance
I am not quite clear what happened when you ran r12571. If there was no Registry Error, that suggests that loading was not done when Audacity launched, which is as intended.kirk202 wrote:I think it may be Audio Unit AUMatrixReverb. I noticed that it didn't work in r1257, no error message, looked like it worked but nothing changed. Never got the Registry Error in r1257 either. But in 2.0.4 unchecking Audio Units got rid of the Registry Error.
Was Matrix Reverb in the Effect Menu, but when you clicked it in the Effect Menu, nothing happened?
Yes, it was in the Effect Menu, when checked in preferences and had Audacity scan for plugins. Never got a registry error with r1257, even with all plugins check for scanning. This was actual working of the plugins on a recording.
First I set it up so that the plugins wouldn't load, next I loaded them and still not registry error. So I checked the AUs and they all worked except for Matrix Reverb...it came up just like normal, could make adjustments,etc, but did nothing except disappear like it would ordinarily do when you tell it to do it, but it didn't do anything, didn't even register in the Undo. Found this out when I hit Cmd-Z to undo and my recording go erased. It acts like it works but doesn't.
I downloaded 2.0.5 and get the registry error if the "(Load) AudioUnits" is checked. All the other plugins load without a problem. The Matrix Reverb doesn't work in 2.0.5 either, same action & result as in r1257.
The AUs don't show up in the menu to select or de-select when you tell Audacity to scan the plugins so I don't know how to isolate that group to work with them. Did a search but couldn't find anything matching Matrix Revert, AU, audio units or Apple.
Wish I could be more help.
Thanks for your help Gale.
Kirk
Kirk
- Quality Assurance
Thanks for testing.
To be clear, the Effects Preference "Rescan VST Effects" only scans for VST plug-ins. There is no dialogue to choose which Audio Units to load.
The intention of r12571 (if the Effects Preference is set to enable Audio Units) is that there is a scan of Audio Units, but not a load. This should mean that if an Audio Unit effect has a prompt or a warning, you should not see that prompt/warning until you actually choose the effect from the Effect Menu. So that seems to be working correctly from your description.
As I understand it AU Matrix Reverb comes with Macs and is free, so I have no idea why it gives you a registry error. It doesn't give me that error. Note that Matrix Reverb cannot be used on a mono track .
If Matrix Reverb gives you a registry error, please contact Apple support.
