Audacity cassette converter software
Shazcoogan
Hi I have recently purchased a cassette converter which came with a setup cd. But I have an iPad 2 so I was wondering if their is a software download that I could get. I'm currently using iOS 6.1.3. Thank you.
Re: Audacity cassette converter software
Audacity will not run on an iPad. Did the web site of the converter say you could run it on an iPad?
- Quality Assurance
You will need a Windows, Mac OS X or Linux computer to run Audacity.
You may be able to use one of the iPad apps mentioned here:
http://manual.audacityteam.org/o/man/fa ... tml#mobile
but we cannot assist you in making that choice.
