How to change BIT DEPTH
Help for Audacity on macOS.
mrb
Post by mrb » Fri Sep 13, 2013 5:18 am
How does one change the Bit Depth?
Re: How to change BIT DEPTH
Post by kozikowski » Fri Sep 13, 2013 6:20 am
Audacity always works internally at 32-floating, but you can make the Export be anything you want by File > Export > Other Uncompressed Files > Options.
If you really meant how to change the MP3 Export Quality, that's contained in the Options panel for MP3 Export. You Export to MP3 by installing the "Lame" software.
Robert J. H.
Post by Robert J. H. » Fri Sep 13, 2013 7:55 am
The bit depth, or sample format is also available from the track drop-down menu (16/24 bit integer or 32 bit float).
