Hi!
Everytime I try to open a WAV file, audacity crashes unexpectedly and I can't explain why. Yes, I removed audacity completely from my system and installed the newest version (2.0.4), but it still crashes when I try to open any WAV file.
See attached file for more infos. Any ideas?
Can't open WAV files
- Quality Assurance
Re: Can't open WAV files
Thanks for the report.
Please either use this test build http://gaclrecords.org.uk/test-builds/a ... -2.0.4.zip which should not crash so much, or go back to 2.0.3 http://audacity.googlecode.com/files/au ... -2.0.3.zip .
See here for explanation (first item) http://wiki.audacityteam.org/wiki/Relea ... nd_Exports .
