Audacity 2.0.4. crashes after installation
Help for Audacity on macOS.
LeoW
Post by LeoW » Tue Sep 10, 2013 11:04 am
I'm working fine with Audacity 2.0.2 until now. A very fine and useful program.
But after have I have downloaded V 2.0.4. and installed, every time I try to open an exciting file: the program stops.
There is a report that will be sent to Apple but at restart the program again the same problem.
A have removed the program and reinstalled V 2.0.2. This program works as always fine. :D :D
How can I solve the problem and install V 2.0.4. as it should be. ?????
Thank you for your help.
Re: Audacity 2.0.4. crashes after installation
Post by Gale Andrews » Tue Sep 10, 2013 12:46 pm
Please try the build in this topic http://forum.audacityteam.org/viewtopic ... 47&t=74504 .
Does it reduce the number of crashes?
LeoW
Post by LeoW » Tue Sep 10, 2013 4:23 pm
Thank you for your suggestion :D
I downloaded Audacity 2.0.5-alpha-sep 10 2013 and replaced Audacity.app in Audacity 2.0.4 with the Audacity.app in the download. :idea:
The program works fine. The help files, in necessary, I can retrieve from the net.
Greetings, Leo.
billw58
Post by billw58 » Tue Sep 10, 2013 6:18 pm
LeoW wrote:Thank you for your suggestion :D
Greetings, Leo.
You really want Gale's "revert-r12334" build. I'm surprised the 2.0.5-alpha nightly fixed the problem.
-- Bill
Post by Gale Andrews » Tue Sep 10, 2013 6:38 pm
Greetings, Leo.
-- Bill
I think Leo may have tried that "revert-r12334" build. The build will still say "Audacity 2.0.5-alpha-sep 10 2013" in the "Welcome Screen" and "About Audacity" because that's what the current version string is set to.
