Can't find temporary files after Audacity Crashed
Help for Audacity on macOS.
Terry McClean
Post by Terry McClean » Mon Sep 09, 2013 11:05 pm
Using;
Macbook Pro, OS X 10.5.8
Audacity 2.0.2
I was recording a live dj set and memory ran out on my macbook. Audacity crashed and I had to force quit.
I now cannot find the temporary files. Have went to preferences, directories, found the link for the temporary files directory but still cannot find the files.
Any ideas?
Re: Can't find temporary files after Audacity Crashed
Post by Gale Andrews » Tue Sep 10, 2013 1:34 am
Were you recording into a saved project? If so, the audio data is in the _data folder for the project.
Either way, have you restarted Audacity? If you are lucky you will be presented with the Automatic Crash Recovery dialogue . Does that dialogue appear?
