Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
ronbo
Post
by ronbo » Fri Sep 06, 2013 3:04 am
hello, first time here
i get an error message that says "cannot save project"
i recorded a song from my yamaha successfully but i cannot seem to save the song and then move on to convert to mp3
i am using a new mac.
i also might mention that i have used audacity with windows xp for years
i really am confused
regards
ron
Moderator note: Please do not tag new queries onto existing unrelated or vaguely related threads, it's always better to start a new thread for a new topic. I split this off for you and gave it a more appropriate title.
- Quality Assurance
Post
by Gale Andrews » Fri Sep 06, 2013 11:13 am
Try File > Export for your song and save it to your Desktop as an AIFF (you can change the folder you save the song to).
Then Audacity > Quit Audacity and make sure your are following the installation instructions correctly:
http://audacityteam.org/download/mac . You should not be running Audacity from the DMG, in case that is what you are doing.
