Hello-
I downloaded Audacity 2.0.3.dmg onto my Mac 10.6.8, imported a MP3 song to do fade-outs at the end, however the EFFECTS menu is grayed out.
I appreciate help with this! Where might I find a good how-to for music fade-ins and fade-outs? I'm fitting music to my photo stills slideshows that I create in iPhoto.
Thank you for this!
Newbie can't get started!
amazingtweety57
- Quality Assurance
Re: Newbie can't get started!
Press the yellow Stop button: http://manual.audacityteam.org/o/man/fa ... tml#grayed .amazingtweety57 wrote:I downloaded Audacity 2.0.3.dmg onto my Mac 10.6.8, imported a MP3 song to do fade-outs at the end, however the EFFECTS menu is grayed out.
The Manual is a good place to look http://manual.audacityteam.org/o/man/fa ... linearfade .amazingtweety57 wrote: Where might I find a good how-to for music fade-ins and fade-outs?
