Getting Audacity to open after downloading
Help for Audacity on macOS.
foxyface14
Post by foxyface14 » Mon Sep 02, 2013 11:10 am
In attempting to download Audacity I ended up with finding it running as an Application - which I only discovered when I tried to open it on the desktop of my Mac 10.6.8 via a zip for a second time. I then transferred this Application to Trash and downloaded Audacity again via audacity-macosx-ub-2-1.0.3.dmg but nothing I do will allow me to open Audacity and achieve a Project Window on the desktop. The Audacity icon which has appeared in the dock brings up nothing on the desktop when double-clicked. I am a relative novice at this and all I want to do is transfer some old vinyl records and some cassette tapes to my computer and from there to an iPod much as I do with CDs using iTunes. Although I have the correct cables from the Tape deck phones outlet to the inline jack on the back of the computer I can't get any music playing through the computer into the computer speakers either. Any advice from those more experienced in this field would be most gratefully received.
Re: Getting Audacity to open after downloading
Post by Gale Andrews » Mon Sep 02, 2013 2:09 pm
foxyface14 wrote:In attempting to download Audacity I ended up with finding it running as an Application - which I only discovered when I tried to open it on the desktop of my Mac 10.6.8 via a zip for a second time. I then transferred this Application to Trash and downloaded Audacity again via audacity-macosx-ub-2-1.0.3.dmg but nothing I do will allow me to open Audacity and achieve a Project Window on the desktop. The Audacity icon which has appeared in the dock brings up nothing on the desktop when double-clicked.
Drag all the Audacity folders to Trash and unmount any Audacity DMG's that are mounted.
Then download Audacity from here http://audacityteam.org/download/mac and be sure to follow the installation instructions mentioned there.
If there are still problems after that please let us know.
foxyface14 wrote:I am a relative novice at this and all I want to do is transfer some old vinyl records and some cassette tapes to my computer and from there to an iPod much as I do with CDs using iTunes. Although I have the correct cables from the Tape deck phones outlet to the inline jack on the back of the computer I can't get any music playing through the computer into the computer speakers either.
OS X does not allow inputs to play in the speakers.
You can try Transport > Hardware Playthrough or Transport > Software Playthrough in Audacity.
If neither let you listen to the input, try LineIn from http://www.rogueamoeba.com/freebies/ .
Post by kozikowski » Mon Sep 02, 2013 2:19 pm
That works for me on all my Macs. Sometimes I forget and leave that running when I'm trying to record a microphone. That's not a good combination.
