Profire 610 compatibility with Audacity recording
Re: Profire 610 compatibility with Audacity recording
Koz, I've solved the problem of recording external audio to Audacity using Profire 610. Profire 610 has separate mic and instrument combined XLR/1/4" TRS plugs on the front of the unit. There are also 2x 1/4" TRS input plugs on the rear. I had been attempting to record from external sources using the rear input plugs. As a last resort I plugged the inputs into the front plugs and Audacity monitored and recorded the audio. What is particularly advantageous is that the front input plugs each have their own gain knob. With the demise of Toast Spin Doctor a working Audacity is a welcomed relief. Thanks Again for all of your support.
