adjusting start/finish
Help for Audacity on macOS.
frisbee
Post by frisbee » Sat Aug 24, 2013 9:54 pm
How can I make fine adjustments to the start or finish time of a selection? Cursor always snaps to nearest full second, but I sometimes need fractions of a second.
waxcylinder
Re: adjusting start/finish
Post by waxcylinder » Sat Aug 24, 2013 9:58 pm
uncheck the snap-to box at the bottom left of your Audacity window.
See: http://manual.audacityteam.org/o/man/se ... .html#snap
frisbee
Post by frisbee » Sun Aug 25, 2013 5:05 pm
Thanks: never quite understood what that box did: got the hang of it now.
