2.0.3 on 10.8.4 Crashing on startup due to Waves[SOLVED]
Help for Audacity on macOS.
strikingtwice
Post by strikingtwice » Tue Aug 20, 2013 1:51 am
I have two separate crash logs. One crashed on thread 59 ThreadSpool? and the other after I tried to restart my computer on thread 0, but after getting a few weird error messages, like Can't find Core Pointer Function.
Sorry for the links, but the message was too long for the board.
https://www.dropbox.com/s/ddmxd2sia9vq1 ... h81913.txt
https://www.dropbox.com/s/nljii3e3wq0fd ... 13%202.txt
Re: 2.0.3 on 10.8.4 Crashing on startup
Post by Gale Andrews » Tue Aug 20, 2013 3:09 am
Thanks for the reports.
Waves 9 Audio Units or other Waves versions aren't compatible with Audacity at the moment, as described in the 2.0.3 Release Notes: http://wiki.audacityteam.org/wiki/Relea ... ram_Launch .
strikingtwice
Post by strikingtwice » Tue Aug 20, 2013 3:25 am
Great, I will try that. I haven't kept up on the release notes as I haven't used audacity in quite some time. Thank you for the link and advice.
strikingtwice
Post by strikingtwice » Tue Aug 20, 2013 4:26 pm
WOrked, thank you.
Re:2.0.3 on 10.8.4 Crashing on startup due to Waves[SOLVED]
Post by Gale Andrews » Tue Aug 20, 2013 4:36 pm
strikingtwice wrote:WOrked, thank you.
Thanks. I'll lock this topic now.
I hope that for either 2.0.4 or 2.0.5 we'll be able to improve the experience so that at least you can launch Audacity with Waves present.
