How to listen to internal sounds while recording?
Help for Audacity on macOS.
dub1808
Post by dub1808 » Tue Aug 13, 2013 10:38 pm
Hi there guys --
I was curious on how to listen to internal sounds in Audacity while recording. I'm trying to commentate on Minecraft so I use Soundflower to make the output from the game be the input in Audacity. I also need to listen to the game at the same time. I tried using a Multi-Output setup in the Audio MIDI setup but it didn't seem to be working.. how can I listen to Minecraft while also recording it in Audacity?
Thanks,
dub1808
billw58
Re: How to listen to internal sounds while recording?
Post by billw58 » Wed Aug 14, 2013 2:09 pm
This sounds like a Soundflower support question, but ...
Please see this page, in particular the section on how to use Soundflowerbed.
http://manual.audacityteam.org/man/Tuto ... ack_on_Mac
-- Bill
