Drag only in whole second increments[SOLVED]
Help for Audacity on macOS.
JeffCarlin
Post by JeffCarlin » Fri Aug 09, 2013 11:05 pm
I'm trying to select a 30 second piece of a song to be used as a ringtone. In order to set the boundaries, before I delete what is not needed, I dragged the Boundary line to my starting point. However, the drag only occurs in full second increments. Unfortunately, I want to start the ringtone at 31.5 seconds. I could swear I used to do this when I ran Audacity on a Windows box. Can anyone help?
Thanks.
Re: Setting Boundary
Post by steve » Sat Aug 10, 2013 12:18 am
Uncheck "Snap To" in Selection Toolbar.
See here for more information: http://manual.audacityteam.org/o/man/fa ... .html#snap
JeffCarlin
Re:Drag only in whole second increments[SOLVED]
Post by JeffCarlin » Sat Aug 10, 2013 12:40 am
Oh, man, I can't believe I missed that. Thanks very much.
