Can't save files to Volumes/ (DMG)[SOLVED]
Help for Audacity on macOS.
radazex
Post by radazex » Fri Aug 02, 2013 3:17 am
I am trying to save a file on Audacity, but all I get is:
Could not save project. Perhaps Volumes/ Audacity 2.0.3/ (name here) is not writable or the disk is full.
I tried this on the alpha on 2.0.4, and the current 2.0.3. Neither worked. If I could get some help, that'd be great :).
billw58
Re: Can't save files
Post by billw58 » Fri Aug 02, 2013 1:35 pm
You are trying to save to the DMG. Please drag the "Audacity" folder from the DMG to your Applications folder, then run Audacity from there.
-- Bill
radazex
Post by radazex » Fri Aug 02, 2013 1:53 pm
Thank you so much! You guys here are so helpful :)
