Gverb for the Mac?
Gverb for the Mac?
Hey, I'm new to audacity, and I'd like to have "Gverb" in the effects I can choose. How can I get this effect? Thanks for the help.
Re: Gverb for the Mac?
Unfortunately GVerb got missed out from the 2.0.3 Audacity release, but see here for a solution: http://forum.audacityteam.org/viewtopic ... 78#p207578
Update: I checked the download link in that post and it does not seem to be working.
Audacity 2.0.4 alpha is available here: http://www.audacity.homerow.net/index.php?dir=mac%2F
or you can wait until Audacity 2.0.4 is officially released (should be later this year).
I know I sound like an idiot, but can I have a detailed instructions on how to download everything I need to get Gverb?
- Quality Assurance
To make it less confusing I updated http://forum.audacityteam.org/viewtopic ... 78#p207578 . Please read that topic. The latest alpha development builds noted there (and 2.0.4 release later this Autumn) will contain a new built-in reverb effect to replace GVerb (that is, GVerb will not be included in 2.0.4 release and may be removed from the development builds at any time).radazex wrote:I know I sound like an idiot, but can I have a detailed instructions on how to download everything I need to get Gverb?
So if you want GVerb, it is probably best to make sure you have the current Audacity 2.0.3 release from http://audacityteam.org/download/mac . Read the installation instructions for Audacity on that page.
When you have 2.0.3, download http://gaclrecords.org.uk/swh-plugins-mac-0.4.15.zip, extract GVerb and any other files you want from that zip, put them in the Plugins folder in /Applications/Audacity then restart Audacity.
