My questions:
1. About making multiple tracks into one OR best way to record one continuous podcast
I am recording myself reading from a novel (podcasts that will be distributed). I have to stop often and make corrections (which I have been doing by erasing the mistake and picking up from where I left off. Each time I do this, a new track is started. Is there a better way to do this?
2. How to raise volume and make it consistent throughout?
I experimented with exporting the file with its multiple tracks, (each picking up from where the other left off) and volume was low—lower than it sounded when i played it back in audacity). I did a "select all" and then chose the effect of normalize. This did raise volume it seems but not in all the tracks? Some still sound soft.
[note about last question: I selected one of the tracks that did not increase volume and it chose effect or normalize but no change. In the tracks in which volume did not raise, I hear a sound I cannot isolate and remove. Am wondering if this might have to do with the problem?
I appreciate the help.
Thanks!
