I'm using Audacity 2.0.3 and OSX 10.8.4.
Audacity crashes every time and nothing is working. Here is the crash report.
Nothing working...tried everything.
brotherwolf
- Attachments
- Audacity_2013-07-25-194846_Andrews-iMac.txt
- (99.79 KiB) Downloaded 39 times
- Quality Assurance
Re: Nothing working...tried everything.
Thanks for the report. Audacity is not compatible with Waves Audio Unit plug-ins, as noted in the Release Notes http://wiki.audacityteam.org/wiki/Relea ... ram_Launch .
Here is a step-by-step to disable Audacity support for Audio Unit plug-ins in the audacity.cfg settings file: http://wiki.audacityteam.org/wiki/User: ... ces_on_Mac .
