Tempo Changes Don't Stick
Help for Audacity on macOS.
westfordjoe
Post by westfordjoe » Tue Jul 09, 2013 9:35 pm
I'm trying to change the tempo of various parts of a song that was imported from an AAC file. I highlighted each section separately, then selected Change Tempo from the Effects menu and changed the tempo. Then I saved the file. When I played the song, none of the tempo changes had stuck. I tried this several times and can't seem to get the tempo changes to save.
I'm using Audacity 2.0.3 on a new iMac running OS X 10.8.4.
Thanks!
Re: Tempo Changes Don't Stick
Post by steve » Tue Jul 09, 2013 9:39 pm
Audacity does not "Save" audio files. The "Save" command (File menu > Save) saves an Audacity Project.
Apply the effect in Audacity.
Play the track to ensure that it sounds like you want it to,
then "Export" (File menu > Export) to create a new audio file. The new (exported) file will have the changes that you applied in the project.
westfordjoe
Post by westfordjoe » Tue Jul 09, 2013 9:57 pm
steve wrote:Audacity does not "Save" audio files. The "Save" command (File menu > Save) saves an Audacity Project.
Thanks for your reply. I was playing the track back from within Audacity, right after I changed the tempos is various parts of the track. This is when I noticed that the tempo changes I put in were not there any more.
Post by steve » Tue Jul 09, 2013 10:22 pm
westfordjoe wrote: I was playing the track back from within Audacity, right after I changed the tempos is various parts of the track. This is when I noticed that the tempo changes I put in were not there any more.
Please give exact step-by-step (click by click) instructions for how to reproduce the problem.
westfordjoe
Post by westfordjoe » Tue Jul 09, 2013 11:14 pm
I think I found a better way using the Slide Time Scale/Pitch Shift. It seems to introduce fewer defects and, so far, my tempo changes have stuck. Thanks for your help.
Post by Gale Andrews » Wed Jul 10, 2013 8:11 am
Also see the Change Tempo documentation in the Manual for an explanation of the limitations of Change Tempo:
http://manual.audacityteam.org/o/man/ch ... ml#General .
Similar limitations apply to Change Pitch:
http://manual.audacityteam.org/o/man/change_pitch.html .
