Matching audio levels
Help for Audacity on macOS.
[email protected]
Post by [email protected] » Mon Jul 08, 2013 10:14 pm
What is the best way to match audio levels? On the two graphs below I want to match based on the light blue levels in the center, bringing the song on the left up to the level of the song on the right. The attempt here is to bring the voices in the two songs to the same audible level so as to no have to keep adjusting volume controls.
Re: Matching audio levels
Post by kozikowski » Tue Jul 09, 2013 3:11 am
You can't look at the waveforms and tell instantly how loud things are going to be. Worse, if everything is pretty loud to begin with, any adjustment may create damage and distortion.
However, Chris's Compressor was designed to do exactly what you want. He designed it so he didn't have to constantly adjust the volume of his music in the car.
http://theaudacitytopodcast.com/chriss- ... -audacity/
