I have used for years the Windows version with the M-S plugin without any problem.
I just bought an iMac with Mountain Lion and installed the latest Audacity for Mac.
My problem is I can't find an M-S plugin for it.
Any help?
Thanks
M-S plugin with iMac / Mountain Lion
Re: M-S plugin with iMac / Mountain Lion
Which plug-in was that?gorlando wrote:I have used for years the Windows version with the M-S plugin without any problem.
