have installed Audacity 2.0.3 on macbook Air operating on OS 10.6.8
do not get any sound output at all no matter which application i use
system preferences/sound have been set to Soundflower 2chs for both input and output
on the output screen got message "The selected device has no output controls"
pls help
Fabio
no sound output
Re: no sound output
See if this page helps: http://wiki.audacityteam.org/wiki/User: ... ming_audio
