Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
jgladwell2
Post
by jgladwell2 » Thu Jun 13, 2013 2:25 pm
Hi,
I might be being really stupid but I've installed, unistalled, installed and the mac version of audacity directly off the audacity website and every time instead of audacity opening, a window opens asking me to authorize the version of FG-X Mastering Console comes up.
I enter in my details and it says no iLok can be found, and this has happened every time I've tried to use Audacity which I thought was free.
Is there anyone out there who can explain what on earth is going on?
Thanks
- Site Admin
Post
by steve » Thu Jun 13, 2013 2:35 pm
Audacity is free, but "FG-X Mastering Console" (whatever that is) is clearly not free. You will need to either uninstall that, or tell Audacity not to try loading it. Do you have any idea what FG-X Mastering Console is or where it has come from? (It's some sort of plug-in and it is not part of Audacity).
- Quality Assurance
Post
by Gale Andrews » Fri Jun 14, 2013 6:43 am
If you have not found it yet, it will be in one of these four locations:
~/Library/Audio/Plug-Ins/VST
~/Library/Audio/Plug-Ins/Components (user plug-ins)
/Library/Audio/Plug-Ins/Components (system-wide plug-ins)
The "~/Library" is Macintosh HD/<your user name>/Library. Later Mac OS X hides it so use Go > Go to Folder in Finder to get in there.
