Hello,
I recently recorded a lecture using a USB audio flash drive (I know, not the most ideal but the only thing I had on me at the time). Anyway, there are times when the white background noise is so loud that I can't hear what the speaker is saying when she crosses the room. Is there a way to decrease the 'white noise' and increase the vocals using Audacity. I am new to this kind of software so any input is welcome, even if it's a suggested other program to use.
Thanks for your input.
KMS40
reducing background white noise, increasing voice volume
- Quality Assurance
Re: reducing background white noise, increasing voice volume
The only likely tool is Effect > Noise Removal, but please attach about 6 seconds of WAV file that has the noise on its own followed by the noise and voice mixed together.
See here http://forum.audacityteam.org/viewtopic ... 49&t=72887 for how to make a WAV audio sample and here http://forum.audacityteam.org/viewtopic ... 49&t=64936 for how to attach it to your post.
Thanks
Thanks
