Time shift tool moves all the tracks[SOLVED]
Help for Audacity on macOS.
hairless
Post by hairless » Wed Jun 12, 2013 11:57 pm
HI, I can't seem to move tracks properly using the time shirt tool... When I select Time shirt tool, and then select the track I want to move, all the tracks move - not just the one i've selected. It's driving me crazy. Any help would be great. Cheers
Re: Problem with time shift tool
Post by steve » Thu Jun 13, 2013 12:09 am
hairless
Re:Time shift tool moves all the tracks[SOLVED]
Post by hairless » Thu Jun 13, 2013 12:16 am
Thanks - that was it... It's been driving me nuts for 2 hours!!! I'm just migrating from Cooledit to Audacity so everything is a little strange... Cheers
