Recording on IMac
Help for Audacity on macOS.
Rafy
Recording on IMac
Post by Rafy » Wed Jun 12, 2013 8:39 pm
This is the first time that I am trying to record on my computer using Audacity 2.0.3, from my keyboard, I can not get recorded.
I have downloaded Core Audio, Lame,Soundflower(2Ch), and per suggestions read on this forum I have purchased Behringer UCA 202.
The setting that I have selected is "Core Audio", "Builtin Output", and for input "Soundflower(2ch)", and "stereo input".
I have read all the Tutorials regarding recording and have followed their suggestions, but still no recording.
I know this may be basic for most of you but it is new for me and I need your help, PLEASE.
billw58
Re: Recording on IMac
Post by billw58 » Wed Jun 12, 2013 9:18 pm
What are you trying to record? Sound playing on the computer? Sound from some external device such as a cassette or turntable? From an external microphone? From the internal microphone?
What model of iMac do you have? From your description is seems to have a built-in stereo input.
Soundflower is for recording the sound playing on your computer.
The UCA-202 is for recording from an external device.
LAME is for exporting MP3 files of your recordings.
-- Bill
Rafy
Post by Rafy » Wed Jun 12, 2013 9:32 pm
Thanks Bill
I have IMAC 10.6.8, & I am trying recording from an external source, my keyboard.
Rafy
billw58
Post by billw58 » Wed Jun 12, 2013 11:33 pm
As far as I recall, all iMacs still have a 1/8" line level input jack. What output are you using from the keyboard?
This manual page may help: http://manual.audacityteam.org/o/man/tu ... ument.html
-- Bill
Rafy
Post by Rafy » Thu Jun 13, 2013 7:30 pm
Hi Bill
My connections are fine I am using an RCA jack connection to the Musical Keyboard output line, and the 1/8 jack to the computer, now here I have 2 choices, the earphone or one other, I can also connect to the computer via Behringer and the USB Port. I think my problem is the settings on the Audacity and their combination with sound settings on the computer. Thanks for your help.
Rafy
billw58
Post by billw58 » Fri Jun 14, 2013 3:47 am
Use the "other" 1/8" input on the iMac. The symbol is a circle with two inward-pointing arrows.
See the illustration on this page: http://manual.audacityteam.org/o/man/tu ... .html#Macs
In Audacity, on the Device Toolbar ( http://manual.audacityteam.org/o/man/de ... olbar.html )
select "Built-in Input" or "Line Input" or similar.
More details about selecting the recording input in Audacity can be found on this manual page:
http://manual.audacityteam.org/o/man/tu ... input.html
To hear what you are doing, check the Transport menu and make sure that Software Playthrough is checked.
-- Bill
