Unable to select anything off Edit tool bar
Help for Audacity on macOS.
AyahAli3
Post by AyahAli3 » Tue Jun 04, 2013 5:22 pm
For some reason i cant delete or copy anything from my audio. I highlighted the areas I wanted to delete but none of the editing tools are working. they are all greyed out and non-selectable. HELP!!!
Re: Unable to select anything off Edit tool bar
Post by steve » Tue Jun 04, 2013 5:55 pm
You probably have playback paused. Try pressing the Stop button.
