I'm using a Macbook pro and I had an older version of Audacity (1.3??) which worked fine. I just downloaded the 2.0 DMG and the zip and they both crash every time I try to launch them. I running OS 10.6.8. Any help would be appreciated!!
Thanks in advance.
Audacity crashes every time on startup
- Quality Assurance
Re: Audacity crashes every time on startup
Sorry you have a problem, but this is documented in many messages on this Mac board and in the Release Notes .
If you need step-by-step help please see http://wiki.audacityteam.org/wiki/User: ... ces_on_Mac .
If problems persist after disabling plug-ins, please attach a Mac crash report and say how exactly you are launching Audacity. For example are you launching it by opening a file?
Please see here for how to attach files to this Forum:
http://forum.audacityteam.org/viewtopic ... 49&t=64936 .
