I tested that on my Mac mini - Choose... , navigating and selecting a folder you can write to seems to work fine.vanillaspice wrote:Clicking on Choose and navigating to the folder doesn't work, only typing the location.
Found and opened audacity.cfg. Found TempDir= (I had never specified it), copied and pasted the text into the Go to Folder dialog, and it went there. The specified TempDir folder exists, but is in a hidden folder named "Private"•You're going to need to enter the Go menu, hold Option, and select Library.
•Then you're going to navigate to Application Support>audacity>audacity.cfg.
•Open audacity.cfg with TextEdit and find TempDir=.
•It should have the temporary directory you specified there. Cut that text.
•Start Audacity.
•Return to Audacity>Preferences>Directories and paste the desired directory text.
•If you see Free Space: xyz GB, then it works, and you can click OK.
•If it continues to say that Free Space is not available because the specified location does not exist, manually type in the desired location.
I somewhat doubt going back to a vanilla installation is going to help.RightWingNutter wrote:I'd like to delete, then reinstall it fresh. I can delete its folder in Application Aupport and the zy folder in /var/folders. Besides the app itself, is there anything else I should trash before reinstalling?
Code: Select all
[Directories]
TempDir=/Users/edwardnutter/Desktop/audacity _temp
