Temporary Folder
Help for Audacity on macOS.
vanillaspice
Temporary Folder
Post by vanillaspice » Tue May 14, 2013 8:24 pm
Since upgrading to v.2.0.3, I tried making a recording, the program crashed, so I wanted to try again but changing my temp folder.
When I try to do that, first, it says that "Space remaining is not available because the above location doesn't exist."
Then, if I save that location and quit Audacity for the change to take effect, it will refuse to start up, saying that it can't find a proper place to write temp files, and to please visit the preferences. I click through, and the program shuts down.
Does anybody else have this problem? I would really like to NOT use the default location, as it's on my system drive!
Re: Temporary Folder
Post by steve » Tue May 14, 2013 9:36 pm
What location are you trying to use for the temporary folder?
Check that the path that you set in Audacity is exactly correct and that it is a location where you have read/write permissions.
vanillaspice
Post by vanillaspice » Tue May 14, 2013 10:10 pm
It doesn't matter the location. It could be /Volumes/Iomega_HDD/AudTemp (which I had been using before) or it could even be /Users/(MyUserName)/Desktop/audacity_temp/ with everyone set to read and write. For some reason, it refuses to look there when I have it open and, if I set that location anyway, I have to delete the location from /HDD/Library/Preferences/net.sourceforge.audacity.plist to get the program to start up.
Post by kozikowski » Tue May 14, 2013 10:18 pm
Have you ever done Go > Desktop > Utilities > Disk Utilities > <your system drive> > Verify Disk and Repair Permissions? Actually you can do that to all your connected drives although they will only allow Verify.
If you have puzzling permissions issues, that maybe worth a shot.
Post by steve » Tue May 14, 2013 11:16 pm
vanillaspice wrote:it could even be /Users/(MyUserName)/Desktop/audacity_temp/
Does "audacity_temp" exist on your Desktop?
vanillaspice
Post by vanillaspice » Tue May 14, 2013 11:28 pm
It did, but it doesn't any longer.
Post by steve » Wed May 15, 2013 12:40 am
How are you setting the folder? Are you typing the path or clicking on "Choose" and selecting it? Try both.
vanillaspice
Post by vanillaspice » Wed May 15, 2013 12:43 am
That appears to be it.
Clicking on Choose and navigating to the folder doesn't work, only typing the location.
RightWingNutter
Re: Temporary Folder fatal error
Post by RightWingNutter » Wed Jul 03, 2013 6:24 pm
I have a similar problem, but Audacity crashes without giving me the opportunity to select a folder. I have run permission repair on the drive.
Audacity version 2.0.3.0
(started happening on 2.0.2 so I deleted the app and upgraded.)
Mac OS version 10.6.8
Upon launch get the a dialog:
Message
Audacity could no find a place to store temporary files.
Please enter an appropriate directory in the preferences dialog.
Audacity then quits without giving me a chance to try to get to preferences. One time it stayed in memory and I was able to switch to it. There was no preferences option showing on its menus, nor a quit option. Quit from the dock didn't work so I had to force quit.
Selecting Reopen gives the same result. Restarting and opening gives the same result.
Crash report below:
Code: Select all
Process:         Audacity [5001]
Path:            /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
Identifier:      net.sourceforge.audacity
Version:         2.0.3.0 (2.0.3.0)
Code Type:       X86 (Native)
Parent Process:  sh [4998]
Date/Time:       2013-07-03 10:48:43.683 -0700
OS Version:      Mac OS X 10.6.8 (10K549)
Report Version:  6
Interval Since Last Report:          -30659 sec
Per-App Interval Since Last Report:  213 sec
Per-App Crashes Since Last Report:   3
Anonymous UUID:                      FFB255D4-7F19-4874-9154-03D9D434FE18
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000003
Crashed Thread:  0  Dispatch queue: com.apple.main-thread
Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
0   Audacity                      	0x0035dd5a ExtImportPrefs::PopulateOrExchange(ShuttleGui&) + 762
1   Audacity                      	0x0035eb75 ExtImportPrefs::ExtImportPrefs(wxWindow*) + 1013
2   Audacity                      	0x00183e4a PrefsDialog::PrefsDialog(wxWindow*) + 1850
3   Audacity                      	0x000423ea AudacityApp::InitTempDir() + 826
4   Audacity                      	0x00043b94 AudacityApp::OnInit() + 2212
5   Audacity                      	0x000461d1 wxAppConsole::CallOnInit() + 17
6   Audacity                      	0x0053eec0 wxEntry(int&, wchar_t**) + 112
7   Audacity                      	0x0003e6a8 main + 24
8   Audacity                      	0x0003e44e _start + 216
9   Audacity                      	0x0003e375 start + 41
Thread 1:  Dispatch queue: com.apple.libdispatch-manager
0   libSystem.B.dylib             	0x92658382 kevent + 10
1   libSystem.B.dylib             	0x92658a9c _dispatch_mgr_invoke + 215
2   libSystem.B.dylib             	0x92657f59 _dispatch_queue_invoke + 163
3   libSystem.B.dylib             	0x92657cfe _dispatch_worker_thread2 + 240
4   libSystem.B.dylib             	0x92657781 _pthread_wqthread + 390
5   libSystem.B.dylib             	0x926575c6 start_wqthread + 30
Thread 2:
0   libSystem.B.dylib             	0x92657412 __workq_kernreturn + 10
1   libSystem.B.dylib             	0x926579a8 _pthread_wqthread + 941
2   libSystem.B.dylib             	0x926575c6 start_wqthread + 30
Thread 3:
Thread 0 crashed with X86 Thread State (32-bit):
  eax: 0x00000003  ebx: 0x0035da6b  ecx: 0x0003ebb5  edx: 0x00000000
  edi: 0xbffff140  esi: 0x01990e00  ebp: 0xbffff188  esp: 0xbffff0f0
   ss: 0x0000001f  efl: 0x00010246  eip: 0x0035dd5a   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
  cr2: 0x00000003
Binary Images:
    0x1000 -   0xaa6fe7 +Audacity ??? (???) <432D620E-B299-E7F8-BB23-54A599E23A09> /Applications/Audacity/Audacity.app/Contents/MacOS/Audacity
 0x108f000 -  0x10dbffb  com.apple.audio.midi.CoreMIDI 1.7.1 (42) <FB4D4B64-6ABB-679E-3AA8-21DE9062B4C1> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
 0x1174000 -  0x1175ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
 0x17e7000 -  0x17ebff7  com.apple.CommonCocoaPanels 4.0 (16) <30D57C5A-2C5E-3A3E-A9D8-F5E968322AD6> /System/Library/CoreServices/CommonCocoaPanels.bundle/Contents/MacOS/CommonCocoaPanels
0x8fe00000 - 0x8fe4163b  dyld 132.1 (???) <4CDE4F04-0DD6-224E-ACE5-3C06E169A801> /usr/lib/dyld
0x90003000 - 0x9010ffe7  libGLProgrammability.dylib ??? (???) <6167CEB0-D8D6-C4D9-DD74-49755ADB540F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x90159000 - 0x9015aff7  com.apple.audio.units.AudioUnit 1.6.7 (1.6.7) <93EC71F1-4D4E-F456-8EFE-32E7EFD7A064> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x9015b000 - 0x90161fe7  com.apple.CommerceCore 1.0 (9.1) <521D067B-3BDA-D04E-E1FA-CFA526C87EB5> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x90162000 - 0x9045cfef  com.apple.QuickTime 7.6.6 (1799) <9C110DFE-9171-20C1-C4E5-62BE8853D18A> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x9045d000 - 0x9049fff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <8A4721DE-25C4-C8AA-EA90-9DA7812E3EBA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x904a0000 - 0x9054cfe7  com.apple.CFNetwork 454.12.4 (454.12.4) <DEDCD006-389F-967F-3405-EDF541F406D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x9054d000 - 0x9099efef  com.apple.RawCamera.bundle 3.7.1 (570) <AF94D180-5E0F-10DF-0CB2-FD8EDB110FA2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x909ad000 - 0x90a0aff7  com.apple.framework.IOKit 2.0 (???) <3DABAB9C-4949-F441-B077-0498F8E47A35> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x90a9f000 - 0x90aafff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x90ab0000 - 0x90ab3ffb  com.apple.help 1.3.2 (41.1) <8AC20B01-4A3B-94BA-D8AF-E39034B97D8C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x90c13000 - 0x90c74fe7  com.apple.CoreText 151.13 (???) <23F359DA-D845-5C50-4DF3-19E858CF2B2C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90df6000 - 0x90e31ffb  libFontRegistry.dylib ??? (???) <19ED5DE0-D3AF-B229-9193-35D58FE377E5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x9103a000 - 0x91163fe7  com.apple.WebKit 6534.59 (6534.59.8) <66F85037-1A89-F7A1-8781-A621A05AB1CA> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x91164000 - 0x91a47ff7  com.apple.AppKit 6.6.8 (1038.36) <A353465E-CFC9-CB75-949D-786F6F7732F6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x91a54000 - 0x91a68fe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x91a69000 - 0x91e7fff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x91eb5000 - 0x922eaff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x92369000 - 0x92388ff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x92389000 - 0x9238ffff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x92431000 - 0x9256efe7  com.apple.audio.toolbox.AudioToolbox 1.6.7 (1.6.7) <423BDE4D-5082-B6CA-BB2C-E22A037235A4> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x9256f000 - 0x925c2ff7  com.apple.HIServices 1.8.3 (???) <1D3C4587-6318-C339-BD0F-1988F246BE2E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x925e2000 - 0x9262ffeb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <00A1A83B-0E7D-D0F4-A643-8C5675C2BB21> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x92630000 - 0x92630ff7  com.apple.vecLib 3.6 (vecLib 3.6) <FF4DC8B6-0AB0-DEE8-ADA8-7B57645A1F36> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x92631000 - 0x927d8ff7  libSystem.B.dylib 125.2.11 (compatibility 1.0.0) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
0x92859000 - 0x928dbffb  SecurityFoundation ??? (???) <C4506287-1AE2-5380-675D-95B0291AA425> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x929cc000 - 0x929ceff7  com.apple.securityhi 4.0 (36638) <6118C361-61E7-B34E-93DB-1B88108F8F18> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x929f1000 - 0x92a12fe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x931c8000 - 0x93476fe7  com.apple.JavaScriptCore 6534.59 (6534.59.6) <BE3DA425-A441-7181-29C3-37EF345B1010> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x93477000 - 0x9347bff7  libGIF.dylib ??? (???) <2251F789-B187-0837-6E38-A0E5C7C4FA3C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x934d5000 - 0x9350fff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <A6C207E3-7B42-926D-9C93-BE3F50B92496> /usr/lib/libcups.2.dylib
0x93510000 - 0x935dbfef  com.apple.CoreServices.OSServices 359.2 (359.2) <7C16D9C8-6F41-5754-17F7-2659D9DD9579> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x93615000 - 0x937d8feb  com.apple.ImageIO.framework 3.0.6 (3.0.6) <AE641FAD-DF38-AE31-B45B-85AEE7AF3A45> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x937d9000 - 0x937f9fe7  libresolv.9.dylib 41.1.0 (compatibility 1.0.0) <8C2B5FA8-2469-21C7-D297-F95A0FFE5F19> /usr/lib/libresolv.9.dylib
0x93870000 - 0x93885fff  com.apple.ImageCapture 6.1 (6.1) <B909459A-EAC9-A7C8-F2A9-CD757CDB59E8> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x93886000 - 0x938aaff7  libJPEG.dylib ??? (???) <50E17B4D-63D6-24D3-702F-6A6E912A55EA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x938ab000 - 0x938dcff7  libGLImage.dylib ??? (???) <D18E2E76-DBF4-6930-039A-F66CA0D120B3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x93931000 - 0x93964ff7  com.apple.AE 496.5 (496.5) <BF9673D5-2419-7120-26A3-83D264C75222> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x93a72000 - 0x93a75ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <4D766435-EB76-C384-0127-1D20ACD74076> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x93a76000 - 0x93ac6ff7  com.apple.framework.familycontrols 2.0.2 (2020) <596ADD85-79F5-A613-537B-F83B6E19013C> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x93ac7000 - 0x93b36ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <595A5539-9F54-63E6-7AAC-C04E1574B050> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x93b37000 - 0x93b56fe3  libexpat.1.dylib 7.2.0 (compatibility 7.0.0) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x93b57000 - 0x93b94ff7  com.apple.SystemConfiguration 1.10.8 (1.10.2) <50E4D49B-4F61-446F-1C21-1B2BA814713D> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x93ba0000 - 0x93be4ff3  com.apple.coreui 2 (114) <2234855E-3BED-717F-0BFA-D1A289ECDBDA> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x93be5000 - 0x93be8ff7  libCoreVMClient.dylib ??? (???) <37F56237-4ABA-E5B5-968D-70FFE357E8E0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x93bf6000 - 0x93c46fe7  libTIFF.dylib ??? (???) <AB182CEC-188A-F2BC-21E1-0059FD3B2598> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x93c8d000 - 0x93c91ff7  IOSurface ??? (???) <89D859B7-A26A-A5AB-8401-FC1E01AC7A60> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x93cba000 - 0x93d94fff  com.apple.DesktopServices 1.5.11 (1.5.11) <800F2040-9211-81A7-B438-7712BF51DEE3> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x93d95000 - 0x93da1ff7  libkxld.dylib ??? (???) <9A441C48-2D18-E716-5F38-CBEAE6A0BB3E> /usr/lib/system/libkxld.dylib
0x93da2000 - 0x93f1dfe7  com.apple.CoreFoundation 6.6.6 (550.44) <F88C95CD-1264-782D-A1F5-204739847E93> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x93f1e000 - 0x93f1eff7  com.apple.Carbon 150 (152) <8F767518-AD3C-5CA0-7613-674CD2B509C4> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x93f58000 - 0x93f65ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x93f66000 - 0x9401efeb  libFontParser.dylib ??? (???) <D2D0C922-5ED1-3AE9-6F99-707C74DF3E62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x9401f000 - 0x940b7fe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x940bf000 - 0x94151fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x94152000 - 0x9432bfff  libType1Scaler.dylib ??? (???) <04AF2B34-81D4-97E9-BD56-387D37C16F46> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libType1Scaler.dylib
0x9432c000 - 0x9432cff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x949a9000 - 0x949c5fe3  com.apple.openscripting 1.3.1 (???) <2A748037-D1C0-6D47-2C4A-0562AF799AC9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x94a0a000 - 0x94a1cff7  com.apple.MultitouchSupport.framework 207.11 (207.11) <6FF4F2D6-B8CD-AE13-56CB-17437EE5B741> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x94a1d000 - 0x94d3dff3  com.apple.CoreServices.CarbonCore 861.39 (861.39) <5C59805C-AF39-9010-B8B5-D673C9C38538> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94de8000 - 0x94df2fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x94df3000 - 0x94e19ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x95114000 - 0x95114ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x95280000 - 0x95281ff7  com.apple.TrustEvaluationAgent 1.1 (1) <2D970A9B-77E8-EDC0-BEC6-7580D78B2843> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x95282000 - 0x95302feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x95303000 - 0x953f7ff7  libiconv.2.dylib 7.0.0 (compatibility 7.0.0) <061ABF36-8BA9-79C1-6CE7-EC69A4998F51> /usr/lib/libiconv.2.dylib
0x953f8000 - 0x9542bfff  libTrueTypeScaler.dylib ??? (???) <8ADB7D19-413E-4499-C874-13C383F97685> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9542c000 - 0x95490ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x95491000 - 0x95495ff7  libGFXShared.dylib ??? (???) <09540618-2ED1-72C4-61CB-938B35927568> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x95510000 - 0x95776ff7  com.apple.security 6.1.2 (55002) <E88E133F-5FB3-446F-B753-2B8AD577B46A> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x95777000 - 0x95799fef  com.apple.DirectoryService.Framework 3.6 (621.16) <5566E769-6459-78A7-DD2C-1D3068BD3932> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x9579a000 - 0x957a5ff7  libGL.dylib ??? (???) <3E34468F-E9A7-8EFB-FF66-5204BD5B4E21> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x957a6000 - 0x95841fe7  com.apple.ApplicationServices.ATS 275.19 (???) <2E83B3E9-AF39-36FC-5D05-CC1E952098AB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x95a81000 - 0x95ac4ff7  com.apple.NavigationServices 3.5.4 (182) <8DC6FD4A-6C74-9C23-A4C3-715B44A8D28C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x95c1f000 - 0x95c21ff7  libRadiance.dylib ??? (???) <090420B3-CB65-9F7B-5349-D42F2F9693B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x95c22000 - 0x95cbffe3  com.apple.LaunchServices 362.3 (362.3) <15B47388-16C8-97DA-EEBB-1709E136169E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x95cd9000 - 0x95cf1ff7  com.apple.CFOpenDirectory 10.6 (10.6) <D1CF5881-0AF7-D164-4156-9E9067B7FA37> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x95cf5000 - 0x95d39fe7  com.apple.Metadata 10.6.3 (507.15) <74F05E64-2A68-BA10-CCD4-128D164E5A0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x95d3a000 - 0x95d3aff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x95d88000 - 0x95d8dff7  com.apple.OpenDirectory 10.6 (10.6) <0603680A-A002-D294-DE83-0D028C6BE884> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x95ef1000 - 0x95efffe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <33C1B260-ED05-945D-FC33-EF56EC791E2E> /usr/lib/libz.1.dylib
0x95f00000 - 0x95f0eff7  com.apple.opengl 1.6.14 (1.6.14) <82622F67-E032-0BF6-A78D-50B346E8D0FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x95f0f000 - 0x96c87fe7  com.apple.WebCore 6534.59 (6534.59.6) <5C71C61C-0657-1B0E-397F-4D0A81872C93> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x96c88000 - 0x96c9cffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x96ca5000 - 0x96ccdff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <E761F29A-328B-29D9-3DF0-023F2C21E500> /usr/lib/libxslt.1.dylib
0x96e16000 - 0x96f98fe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <60FF302E-5FAE-749B-BC70-0496DC2FBF2D> /usr/lib/libicucore.A.dylib
0x96fe1000 - 0x96fe1ff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <3891A689-4F38-FACD-38B2-4BF937DE30CF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x971ea000 - 0x97254fe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x9743a000 - 0x9744bff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <3036AD83-4F1D-1028-54EE-54165E562650> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x983a0000 - 0x983a9ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x983aa000 - 0x98466fff  com.apple.ColorSync 4.6.8 (4.6.8) <920DD017-8B41-7334-E554-A85DB99EBD5A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x98467000 - 0x9878bfef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x9878c000 - 0x9878cff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x98903000 - 0x989e3fe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x989e4000 - 0x98a25ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <80998F66-0AD7-AD12-B9AF-3E8D2CE6DE05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x98b0e000 - 0x98bdffe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <C618942F-BC01-0565-18CF-477B63C02181> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x98c07000 - 0x98f72ff7  com.apple.QuartzCore 1.6.3 (227.37) <E323A5CC-499E-CA9E-9BC3-537231449CAA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x98f73000 - 0x98f76fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x98fcd000 - 0x990cffe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <316C3B25-6DCA-549A-7728-D5A038F654D8> /usr/lib/libcrypto.0.9.8.dylib
0x990d0000 - 0x99189fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
0x9918a000 - 0x99204fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <156A532C-0B60-55B0-EE27-D02B82AA6217> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x99205000 - 0x99476fef  com.apple.Foundation 6.6.8 (751.63) <69B3441C-B196-F2AD-07F8-D8DD24E4CD8C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x9993e000 - 0x999e6ffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x999e7000 - 0x99a05fe7  libPng.dylib ??? (???) <6C0B95D7-9634-E044-0B79-F1DD56961C33> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x99b4e000 - 0x99b94ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
0x99b95000 - 0x99bd8ff7  libGLU.dylib ??? (???) <6CC3CE6A-7024-C685-EADA-7F9DC27128E2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x99cc1000 - 0x99ccbffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <7486003F-8FDB-BD6C-CB34-DE45315BD82C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x99d08000 - 0x9a4f7557  com.apple.CoreGraphics 1.545.0 (???) <1D9DC7A5-228B-42CB-7018-66F42C3A9BB3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x9a65d000 - 0x9a668ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <287DECA3-7821-32B6-724D-AE03A9A350F9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9a669000 - 0x9a717ff3  com.apple.ink.framework 1.3.3 (107) <233A981E-A2F9-56FB-8BDE-C2DEC3F20784> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9a718000 - 0x9a846fe7  com.apple.CoreData 102.1 (251) <87FE6861-F2D6-773D-ED45-345272E56463> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x9aa2a000 - 0x9aa31ff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9aa37000 - 0x9aae4fe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <9F8413A6-736D-37D9-8EB3-7986D4699957> /usr/lib/libobjc.A.dylib
0x9aae5000 - 0x9abe5fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <BE7FCD73-03B5-25A4-FCA4-D4980F1488D6> /usr/lib/libxml2.2.dylib
0x9ac01000 - 0x9ac01ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <ABF97DA4-3BDF-6FFD-6239-B023CA1F7974> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <2DCD13E3-1BD1-6F25-119A-3863A3848B90> /usr/lib/libSystem.B.dylib
Model: iMac7,1, BootROM IM71.007A.B03, 2 processors, Intel Core 2 Duo, 2.4 GHz, 4 GB, SMC 1.21f4
Graphics: ATI Radeon HD 2600 Pro, ATI,RadeonHD2600, PCIe, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x88), Broadcom BCM43xx 1.0 (5.10.131.42.4)
Bluetooth: Version 2.4.5f3, 2 service, 19 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: WDC WD3200AAJS-40RYA0, 298.09 GB
Parallel ATA Device: OPTIARC  DVD RW AD-5630A
USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0xfa400000 / 3
USB Device: Keyboard Hub, 0x05ac  (Apple Inc.), 0x1006, 0xfa420000 / 6
USB Device: Apple Optical USB Mouse, 0x05ac  (Apple Inc.), 0x0304, 0xfa423000 / 8
USB Device: Apple Keyboard, 0x05ac  (Apple Inc.), 0x0220, 0xfa422000 / 7
USB Device: USB to Serial-ATA bridge, 0x1bcf  (Sunplus Innovation Technology Inc.), 0x0c31, 0xfa430000 / 5
USB Device: USB2.0 Hub, 0x05e3  (Genesys Logic, Inc.), 0x0608, 0xfa440000 / 4
USB Device: USB to Serial-ATA bridge, 0x1bcf  (Sunplus Innovation Technology Inc.), 0x0c31, 0xfa200000 / 2
USB Device: Built-in iSight, 0x05ac  (Apple Inc.), 0x8502, 0xfd400000 / 3
USB Device: MX870 series, 0x04a9  (Canon Inc.), 0x1743, 0xfd100000 / 2
USB Device: Bluetooth USB Host Controller, 0x05ac  (Apple Inc.), 0x8206, 0x1a100000 / 2
USB Device: IR Receiver, 0x05ac  (Apple Inc.), 0x8242, 0x5d100000 / 2
Last edited by RightWingNutter on Fri Apr 24, 2015 4:17 pm, edited 2 times in total.
Reason: code tags added
vanillaspice
Post by vanillaspice » Thu Jul 04, 2013 12:50 am
•You're going to need to enter the Go menu, hold Option, and select Library.
•Then you're going to navigate to Application Support>audacity>audacity.cfg.
•Open audacity.cfg with TextEdit and find TempDir=.
•It should have the temporary directory you specified there. Cut that text.
•Start Audacity.
•Return to Audacity>Preferences>Directories and paste the desired directory text.
•If you see Free Space: xyz GB, then it works, and you can click OK.
•If it continues to say that Free Space is not available because the specified location does not exist, manually type in the desired location.
