Hi all, thanks for the replies,
@ Steve - yes, I am sure you are right about the 'numbers' and I will definitely do some experimentation at different resolutions when I have everything working, and when I feel more confident w/ enhancing etc
@ Koz - what a dummy I am! Yes the device is multi channel, and the 'phono' input is 3/4, so I have tried recording on channels 1-4 and lo and behold I have sound on 3/4, and flat line on 1/2!! So is this how I would record, on 1-4 and then delete 1/2 afterwards?
@ Waxcylinder - I am a 'she'
And wow - I am confused now. I thought I had read on many (internet) places of ppl using 24-bit soundcards w/ Audacity, in fact, I think this is where I got the idea from.
So is this not the case?
Or do you have to tailor the program yourself to do this, to make them 'work together'? Is this some kind of plug-in that's easily installed or is it something quite tech-y, because if so, it is definitely beyond me!
Or is it not a problem as I am on a Mac?
Sorry what is WASAPI?
So I have managed to get the sound in to Audacity now, but now my problem is a massive background buzz, almost as loud as the music! Didn't have this buzz with the USB turntable & Audacity.....could this be a 24bit soundcard compatibility issue?
The soundcard has a phono earth / ground 'knob' so I don't think it's that. As a test I did a short recording into GarageBand on same machine with same equipment and no buzz? So I think the buzz is something to do with Audacity.
Sorry for all the (what i'm sure are) inane questions,
Many Thanks,
