Thanks for the input. Can you please identify your iPod from this list http://en.wikipedia.org/wiki/List_of_iPod_models#Models ?ohjeans wrote:I stumbled onto a fix for this. I used a USB turntable to record my vinyl records into Audacity, then "export Multiple" to turn them into AIFF files. When I loaded the new AIFF files into my iTunes, all was well. However, when I loaded the files from iTunes onto my iPod, the files appeared in the lists, but would not play on the iPod.
Yes, that is one of the fixes because iTunes creates a new AIF when you import the CD, assuming your import settings are set to import files as AIF.ohjeans wrote:However, by coincidence I also had used iTunes to make playlists of each newly-loaded album and had burned each to a CD. So what I did was re-load each just-burned CD into iTunes, OVERWRITING the files I had just used to create the CD in the first place.
If you had not burned a CD, you could have right-clicked over the problem file > Create AIF version to create a new "fixed" version of the file.
Do mean you hid Metadata Editor for the export step in Preferences? In the "fixed" 2.0.4-alpha I tried entering the metadata before export and hiding and not hiding Metadata Editor, but the exported files still have the added space if the metadata has an odd number of characters.ohjeans wrote:For the very first album I converted, I did not use Open Metadata Editor, and instead typed in the album name, genre and other metadata one track at a time as I "exported multiple." The files for this first album played just as they ought to when loaded for the first time onto iPod. For every subsequent album, I used Metadata Editor BEFORE exporting multiple, and no files for those subsequent albums would play on iPod without first going through the burn-a-cd-and-overwrite fix described above.
OK. If you can, please test this 2.0.4-alpha build http://gaclrecords.org.uk/win-nightly/d ... aug-13.zip which contains the fix. Be sure to quit 2.0.3 before running 2.0.4-alpha.ohjeans wrote:My version of Audacity is 2.0.3 running on Windows 7
