mjschmelzer wrote:For the AIFF files I would note that the ones that would not play were files recorded earlier and not on Audacity which were normalized and then exported. As they were single songs I'm not sure how one would use the multiple files export. But probably the solution is in this function. Perhaps there could be a quick something to do at the end of the file to redefine the end. These files already had metadata .. and I also edited some of that data.
The problem that we currently know about is where any of four metadata fields: Artist Name, Track Title, Comments and Copyright have an odd number of characters including spaces (for example, three characters instead of four). If the player reads the AIFF version of these tags rather than ignoring them, it may refuse the file.
Export Multiple doesn't cure this problem, but makes it more likely to happen. This is because you cannot avoid adding Track Title and Track Number to export multiple metadata unless you explicitly set Metadata Editor in Import / Export Preferences to appear at the export step and then clear those two metadata fields before exporting the file.
mjschmelzer wrote:Exporting these AIFF files from Itunes, burning a CD and then re-importing the songs from the CD solved the problem for the AIFF files. (Of course I had to delete the files I started with as there was no fast visual to know which files in iTunes with the same names would play on the iPod and which would not.) This is obviously time consuming however.
OK. A quicker workaround is to create an additional AIFF version of the file in iTunes. See
http://wiki.audacityteam.org/wiki/Expor ... od#convert but choose AIFF encoder instead of MP3 encoder.
mjschmelzer wrote:I tried b.aiff and d.aiff and they play just fine on my 6th Generation Classic.
Thank you very much for testing. If you have any audio players other than iTunes, QuickTime or VLC it would be very helpful if you could test those two files on those. We are most interested in apps only available for Mac which may possibly try to read the AIFF tags.
