Edit or lack of
Help for Audacity on macOS.
Stratguitarman
Edit or lack of
Post by Stratguitarman » Fri May 10, 2013 9:51 pm
I loaded the Wav file and selelcted the part I want to delete and nothing happens. I've tried hitting the delete button and control x and control k - nothing happens it won't let me delete the selected section intro of the WAV file I opened. Any advice/suggestions please?
Re: Edit or lack of
Post by Gale Andrews » Fri May 10, 2013 10:11 pm
Press the yellow Stop button. Please see this link http://manual.audacityteam.org/o/man/fa ... tml#grayed .
Also note that most Audacity shortcuts on Mac use COMMAND, not CTRL.
