opening aiff files produces noise[WORKAROUND]
Help for Audacity on macOS.
ngazidja
Post by ngazidja » Wed May 08, 2013 3:17 pm
I have a couple of aiff files (finder says they are AIFF-C audio) that produce noise when I open them with audacity. One is a constant loud buzzing, the other is mostly silence punctuated by loud buzzing. Both files play fine in iTunes; both are recordings of phone calls off skype - I don't recall what I used to record them, possibly wiretap (they are about five years old).
Any suggestions? I could export them from iTunes in a different format but I don't know how - perhaps you can't any more?
I installed Audacity 2.0.3 from the dmg and I'm using 10.7.5
Any suggestions?
Thanks!
billw58
Re: opening aiff files produces noise
Post by billw58 » Wed May 08, 2013 4:26 pm
The AIFF-C ("compressed") container format can contain many different types of compression.
https://en.wikipedia.org/wiki/AIFF#AIFF ... sion_types
It seems these have a type of compression not recognized by Audacity.
Try converting them to WAV or uncompressed AIFF with Max: http://sbooth.org/Max/
Alternatively, since they play correctly in iTunes, use iTunes to convert them to WAV or MP3 (use the highest quality MP3 setting).
-- Bill
ngazidja
Post by ngazidja » Wed May 08, 2013 4:51 pm
Well, I thought about converting with iTunes, but I can't find an "export" function. But I'll try Max, thanks.
billw58
Post by billw58 » Wed May 08, 2013 7:14 pm
In iTunes:
Go to Preferences, the General section, then click the "Import Options" button. Choose the encoder and options (if available). Close preferences.
Click on the track you want to convert. Click File > Create New Version > Create ... Version (it will indicate the file type you chose in Import Options).
A new track is created.
Find that new track in your iTunes library and move it where you want.
-- Bill
ngazidja
Re: opening aiff files produces noise[WORKAROUND]
Post by ngazidja » Wed May 08, 2013 8:05 pm
Thanks Bill, both answers do what's needed!
Iain.
Post by Gale Andrews » Sat May 11, 2013 5:38 am
Since iTunes can open these files it's quite likely Audacity could if its QuickTime importer was able to get to them, but I suspect the standard WAV/AIFF importer called "libsndfile" is opening them even though it doesn't support the format that is in them. You could look at Help > Show Log... to see what is actually happening.
If you come across any more files like that you could try a similar trick mentioned here if you wanted to. In the Extended Import Preferences create a rule for *.AIFF (or *.AIFC if the files have that extension), drag the QuickTime importer to the top of the list, then uncheck the "Attempt to use..." box and click OK.
